Alarm System's
Old Dec 19, 2006 | 06:42 PM
roor0's Avatar
Question Alarm System's
I have a 1997 240sx Auto. Base model that has no alarm system. I'm in need of a security system because of the increasing rate of auto theft in and around my area(VA, MD, DC).
I am considering the Viper 791XVR system w/ remote start. I plan on installing the system myself because I don't think it would be that difficult.
Is this set-up worth the money and time?
Has anyone put a aftermarket alarm system into any S14?
If so, is there anything important that I would need to know before/during/after I install it?
Any extra parts that I need?
Suggested Links?
But, if anyone else has a better suggestion, feel free to say so.
Info on the Viper Alarm:
Viper 791XV Responder 2-Way Alarm Security System
- 100% BRAND NEW AND UNOPENED! ALL OUR 791XV ARE UNTOUCHED. EMAIL US IF YOU NEED ANY SPECIFIC ACCESSORIES OR MODULES. FULL LINE AVAILABLE. REMOTE START SYSTEMS ARE INTENDED FOR FUEL-INJECTED, AUTOMATIC TRANSMISSION VEHICLES ONLY.
- User-friendly 2-Way Remote with the Ultimate 2-Way Security and Remote Start system!
- Responder Technology: Unique LCD Interface for 2-Way communication of command confirmations and trigger events!
- Confirms all commands with easy-to-understand icons, plus text!
- Alerts users to security system triggers by Beeping or Vibrating!
- Responder alerts you when too far away to hear it.
- Only available 2-Way Remotes with 66-bit Code-Hopping!
- Includes a Belt Clip
- Vehicle Recovery System
- Turbo timer and defroster activation output built-in.
- Parking light flash
- Dedicated 1 button start
- +/- Doorlock Polarity Outputs
- One 4-button Remote
- 5 channels
- 5 zones
- Flashing L.E.D. light
- Valet switch
- Starter Disable built-in
- 6 Tone Revenger Siren
- Remote Panic/Car Finder
Thanks.
-Ro
Old Dec 20, 2006 | 11:42 AM
sk8brdb's Avatar
Viper is a very good company. they bought clifford alarms a little while back. I think it is worth the money.
Old Dec 21, 2006 | 12:50 AM
Mika's Avatar
i think thats the 2 way alarm isnt it? ive got the clifford rsx 3.5 2way which is essentially the same as the viper 2 ways (both DEI). i really like it, ive got the remote start hooked up too (nissan has a neutral sensor pin in the ECU). i'd say go for the alarm since these cars are gettin into the mainstream.
Old Dec 21, 2006 | 02:43 PM
roor0's Avatar
Did any of you guys install the alarm system yourselves?
Is it a good idea to install the remote start into a manual trans??
Old Dec 21, 2006 | 07:55 PM
Mika's Avatar
i had a local guy do the install. I watched the whole time, honestly if youre good with wiring and a multimeter it shouldnt be that bad, just time consuming. As i said before i have the remote start hooked up and i have a 5spd. There is a neutral sensor pin in the ECU. If you run the neutral safety wire from the alarm to this pin in the ECU the remote start will not work unless the car is in neutral.
Old Dec 22, 2006 | 03:28 PM
roor0's Avatar
Mika - Thanks for the advice.
Now all I need to kno is if there is any extra parts I need too have.
Old Dec 23, 2006 | 10:42 PM
otterball21's Avatar
I noticed that the thread is old.. but if you have questions about remote start/alarm/security, let me know I'll help you out.
For some weird reason the 240sx 95 and up needs the accessory isolated,
I got specs on the car if you need it.
Old Dec 24, 2006 | 09:09 AM
Mika's Avatar
extra parts might include another hood pin switch and an actuator for the trunk if you want the trunk to open with the remote. i cant think of anything else you would need besides lots of connectors (t-taps and crimp connectors), a soldering gun and solder, electrical tape, screw drivers,and the all important multimeter.
Old Dec 24, 2006 | 09:43 AM
actually.. check this out....
I don't know why we need to do this to the 95 240sx... but I did it and it's futzing with my car and I'm not happy about it, but check this document out.
NISSAN, 240SX, 1995, Accessory
When doing remote start, this wire must be isolated from the keyswitch with the accessory relay. See direct fax document #1077.
Soooo I look up direct Fax document..
http://www.directechs.com/techtips/p...htips/1077.pdf
Wired it up... exactly. So when you put the key in.. accessory turns on.
That required a spare relay.
Also if you don't have power door locks and you wired some in, you also need a relay for that also.
Old Dec 26, 2006 | 10:32 PM
roor0's Avatar
Otterball21 - I need Specs on a 1997 240sx! and whats the isolated accessories all about; or should i say which ones?
My car has power everything.
- Thanks in advance.
Old Dec 26, 2006 | 10:45 PM
hmmm..
what's your email? I need your email.. it's in a Word document.... :-)
Old Dec 27, 2006 | 12:29 PM
roor0's Avatar
haha
ro_or_r0@yahoo.com
S14_Turbo
Sep 8, 2007 04:58 PM
240Boogyman
Oct 10, 2005 08:24 AM
Amolao
Jul 27, 2004 02:12 AM
richard1
Dec 13, 2003 06:13 PM
Import Fanatix
Nov 12, 2002 05:09 AM
