speaker removal
Old Dec 25, 2005 | 12:28 PM
limpfan's Avatar
speaker removal
hey all, i just got some new speakers for christmas and was wondering how i get to both the fronts and rears. i assume i have to take the door panels out, but im lost on the rears. i see no way to remove the rear speaker deck. if anyone could help me out it would be much appreciated!
Old Dec 25, 2005 | 03:30 PM
Ron Smith's Avatar
Take your back seat out, and pop the panel in which the speakers are located in upward. There is several plastic rivots holding it in. In fact, open your trunk and look under the rear window where the speakers are located. You will be able to see exactly where they are. They pop out on push back in when are done.
Old Dec 25, 2005 | 09:34 PM
Mika's Avatar
you dont need to take the back seat out. just pull the deck cover off and replace. as for the front, just unscrew the door panels and pop them off.
Old Dec 26, 2005 | 06:21 AM
birgir185's Avatar
Re: speaker removal
just for future referance you should state if it's an s13 or s14
Old Dec 26, 2005 | 09:25 AM
from the sounds of "rear speaker deck" it can be confused as to either it's an s13 or s14 coupe.
Just get your fingers under the front edge of the panel and pull up. It'll pop like 12 times - there's 12 or so plastic fasteners under there.
Swap the speakers, make sure you have all the plastic pop things still on the panel, then realign and push down on the panel. it'll pop back into place.
I hope whoever got you the speakers got you 6.75"s all around (s14)... a lot of people think they're 6.5" then run into trouble
Twisted 240sx
Jul 11, 2003 11:12 PM
Driftin180SX
Dec 29, 2002 12:11 PM
Nism0Drifter
Dec 8, 2002 06:25 PM
Import Fanatix
Nov 21, 2002 02:29 PM
AzzySK
Nov 5, 2002 06:15 PM
