wiring up a stereo questions
Old Apr 29, 2007 | 11:10 PM
  #31
DALAZ_68's Avatar
from wut i just checked those are all hooked up properly...
Old May 4, 2007 | 10:13 AM
  #32
LA_phantom_240's Avatar
Maybe the radio is toast.
Old May 4, 2007 | 11:40 AM
  #33
slimbung's Avatar
You did bypass the stock amps right?
Old May 4, 2007 | 12:57 PM
  #34
DALAZ_68's Avatar
i dunno
were are they located???
  #35
Initial Daniel's Avatar
You need to find your stock amplifier and bypass it.
Lets make a check list.
Does the radio come on? If it does, then you're getting Acc, 12v, and Ground.
If not, then you need to find a proper source for power.
Do the speakers come on after the radio has been powered? If they work correctly, then obviously everything is good.
If not, then what are they doing? Crackling? No sound at all? If that is the case there are TWO things you can do as stated before. Bypass the factory amplifier OR Rewire the car, by running your own speaker wiring.
Ok, let me try to clear something up for you if you don't understand WHY the factory amplifier needs to be bypassed.
In an entirely stock system, your stock radio gives out a low audio output. The factory amplifier takes that low output and amplifies it to a higher output so you get better sound from your radio.
An aftermarket headunit has somewhat of a built in amplification system which enables it to output higher watts per channel; that is, the audio output is already amplified!
When you put an aftermarket radio into your car, it is sending an already amplified signal to your factory amplifier which tries to amplify it yet AGAIN. This will NOT work, which is why you won't get sound unless you bypass that factory amplifier.
It's like this:
Radio----->Amplifier---->Speakers
In your case, you want Radio----->Speakers
Bypass that ****!
Old May 4, 2007 | 01:11 PM
  #36
DALAZ_68's Avatar
aite well simply put it powers up and the speakers there is no sounds, zero nada
how do i bypass the amp and were is it located???
Old May 4, 2007 | 04:18 PM
  #37
one is in each door panel and then theres one in between the 2 rear speakers. and he just told you how to by pass them.
Old May 18, 2007 | 11:25 AM
  #38
DALAZ_68's Avatar
basically just cut the wires running into the stock amp to directly into the speakers i assume
Old May 18, 2007 | 11:56 AM
  #39
You can; but it's better to just strip them back and tap on to them.
Old May 18, 2007 | 01:30 PM
  #40
510skater's Avatar
initial dan...you never answered the question of where the factory amp is located...is it that box on the driver side located behind the back panels?
oh nvm i didnt read 1993coupes post
Old May 19, 2007 | 12:49 AM
  #41
It's going to be different for the S14 and S13, I know that sometimes they mount the main amp right between the two rear speakers in the coupe--not sure about the hatch though.
You should be able to tell what it looks like...the only other metal box like that should be the ECU, and thats in the passengers kick panel with a LARGE harness going into it.
garrisonrex
Jan 6, 2009 02:48 PM
Ron83
Apr 23, 2005 02:00 PM
japan-air
Feb 7, 2005 03:20 AM
unstoppablenick
Nov 15, 2003 01:37 AM
s240r
Jun 13, 2003 02:23 PM
