98 240sx auto -> manual conversion?
Old Feb 6, 2004 | 12:36 PM
mwy23's Avatar
i have searched and searched and have not found an answer. from what ive read so far, it seems like anyone that has a 97/98 240sx that is an auto have not done a manual conversion. there have been some that did do it along with a motor swap, however.
my question is this: since the 97/98 is OBDII, i read that a manual conversion is difficult. not the actual swap, but the wiring. is this true? can anyone confirm/deny this? i have a 98 auto and i want to do the conversion. however, im not sure if i should attempt it myself or take it to a professional. do have have to buy all 97/98 parts to have the conversion work?
Old Feb 6, 2004 | 02:02 PM
Sil40_Mayhem's Avatar
i have no idea about the wiring, but i might have some good news about the hardware. the part number for the manual transmission is FS5W71C. now, according to the following sites, it appears to be the same in both the 89-96 240's as well as the 97-98's:
89-96:
http://www.drivetrain.com/nissian4_5sprwd.html
97-98 (scroll up a little above the 350Z info):
http://www.vibratesoftware.com/html_...sions.htm#350Z
now, it would be logical to presume that the trannies should be the same based on this, but i'm not certain. i'd figure that if there were significant changes to the wiring, the part numbers would differ. but that's just me.
anyway, hope this helps.
Old Feb 6, 2004 | 03:15 PM
sr20det power's Avatar
i have a 98 and from wut i've researched when i wanted to do mine is that u need a 98 manual wiring harness to complete it unless u swap, only way i could think of was findin a wrecked 97/98 240 in a junk yard that is manual and strip the parts which is pretty much impossible
Old Feb 9, 2004 | 08:49 AM
drnovascotia's Avatar
Here you go.
s14 5 speed swap
I'm gonna add it to the FAQ's.
Dr.
Old Feb 9, 2004 | 11:55 AM
mwy23's Avatar
great find, thanks doc! do you kno by chance if this swap instruction is for an obdii S14? im assuming so since most of the S14's are obdii.
Old Feb 9, 2004 | 11:59 AM
mwy23's Avatar
nevermind.. i just caught this:
4) Remove all wiring from the trans
Disconnect the wiring to the speed sensor and the OBD-II flywheel rotation sensor. Disconnect the wires which connect to the A/T from next to the fuse box under the hood (4 connections).
Old Feb 9, 2004 | 12:27 PM
kinda said that up there
guess i wasnt really clear...
Old Feb 10, 2004 | 11:01 AM
np
I thought I was obdII, so I figured it would help.
Let us know how it goes if you do it.
Dr.
diego1103
Sep 19, 2006 02:01 PM
Carparthookup
Sep 11, 2005 09:55 AM
anubis
Feb 24, 2005 12:08 PM
spoolin240
Apr 13, 2004 09:46 PM
