auto to manual swap questions, thanks
Does anyone know if the auto driveshaft is going to work with the fs5w71c? Will the auto mount bolt on to the 5spd? Thanks, guys, just making sure I have all the stuff i need before i start.
it depends on the driveshaft if you are taking it out of a s13 and putting it in an s14, or visa versa. If you are doing that you will either have to get one out of your version of car, or getting one made for it. As for the mount, I have no idea, both mounts looked the same on mine, the 5spd bolted straight up to mine.
for s13's you need the half shaft (from the bearing forward) and the mounts are not the same, at least not when i did it.
you can see some pics of what i mean here
------->http://www.cardomain.com/memberpage/353431/3
spoolin240
Apr 13, 2004 09:46 PM
