clunking noise... when, shifting under deceleration
Old Jun 26, 2005 | 02:18 PM
bbs_e30_m3's Avatar
I just bought a '96 240sx SE.
It has 85k miles, and it drives pretty good for a 9 year old car.
One problem that I noticed is that when I am shifting (i.e. 2nd -> 3rd) while the car decelerates, the rear diff area makes a clunking noise.
It only happens when I'm off throttle (i.e. weight shifting forward). It never happens when I'm on the throttle (i.e. weight shifted to the rear wheels).
It also happens when I'm in a gear (i.e. 4th), and cruising at a constant speed... then when I let off the gas quickly, it makes a clunking noise.
Is there a bushing on the rear diff? Anything that I should look for when I jack up the car?
TIA.
-Sean
p.s. Do they sell factory service manual somewhere on the web? (i.e. Helms or Bentley's)
Old Jun 26, 2005 | 02:56 PM
revolutionz_s13's Avatar
there is actually 4 bushings where the diff mounts to the subframe
Old Jun 27, 2005 | 12:20 AM
Levi SPL S14's Avatar
its your subframe bushing have those changed or add spacers to eliminate the thump.
Old Jun 27, 2005 | 07:53 AM
bbs_e30_m3's Avatar
Thanks, I'll have them check out. I take it that it's gonna be a ***** to have it changed due to its location. Oh well.
Old Jul 1, 2005 | 11:18 AM
JDMxDrift's Avatar
Actually, i just added spacers to mine. Took me an hour its really simple.
Old Jul 1, 2005 | 07:46 PM
Preston's Avatar
If it's the SE and has ABS...it probably has LSD. That clunking is the LSD if you have it. It's normal and shouldn't be worried about.
djsilver
Aug 16, 2020 08:07 PM
Purple240
Dec 11, 2005 10:02 PM
JDMxDrift
Dec 16, 2004 09:22 PM
BurnOut
Jun 27, 2004 08:30 PM
luv_2_xl_er_8
Jan 18, 2004 02:03 PM
