clutch
clutch
i have a 92 240sx, the clutch needed to be replaced; also when you would press down on the clutch pedal it wouldnt come up anymore after the clutch engaged unless you would pull it up with your toe. i put a new clutch in it last week and a new slave cylinder and master cylinder. ive bled it. when you push down the clutch it stays all the way down on the floor? also it wont go into gear when the car is running, if you push in the clutch and try to shift it into gear it wont. i thought it was the slave or master cylinder but i have replaced both of those so now im thinking i put the new clutch in wrong but i fallowed the maual and directions that came with the clutch and it went back together just how it came out.
i just changed my master and slave too the other weekend. and mine did do that too with the pedal. you gotta play with the adjustments i think and bleed it good. i also to have to get a clutch cuz right after i changed the cylinders my clutch was going. getting a centerforce dual friction.
i changed the throw out bearing. i messed around with adjusting the rod that goes from the clutch pedal to the master cylinder and it works! thanks monkey boy! but now when the clutch pedal is fully pressed in it makes a growling/whinning sound? what is that? thanks for any help.
nephthys
Feb 28, 2005 06:58 AM
boricuajr
Oct 11, 2004 10:54 PM
haipho123
Jul 25, 2004 11:15 PM
Ray240CA18
Sep 18, 2003 09:58 AM
