Clutch Pedal
Ok, I just finnished reinstalling my trans after a cltch upgrade, and now, when I press down on the clutch pedal, there is no resistance or pressure, it just goes staright to the floor. I already tried adding more fluid, but that didnt work. Does anyone have any idea why there is no reistance to my clutch pedal? Id appreciate your input. Thanks.
you need to bleed it, on the slave cylinder get the 8 or 10mm and open the valve a little bit, have someone press the clutch in, once the clutch is pressed close the valve and release the clutch, then open it and push the clutch back in, then tighten bolt and release clutch....basically repeat until only fluid comes out with not air pockets....
watch ur eyes cuz it burns bad....dont ask lol
hey, my clutch does the same thing, except it goes crashing to the floor and dont come back up.......but i dont have a clutch line at all, I thaught the big spring on the pedal was suposed to make the pedal come back up.
chitodsr
Jan 5, 2008 12:34 PM
x3240racer
Mar 12, 2007 04:17 PM
Matt_240
Nov 4, 2002 06:22 PM
