This is the correct way to install a s13 VLSD in a 91240sx coupe!
Old Feb 10, 2005 | 08:23 PM
onesloweg5's Avatar
First off you need to get 2 bottles of Penzoil Gear oil. You can also add a aditive for VLSD if you want i didnt.
You also need a s13 VLSD with half shafts and 5 bolt axels.
This is for s13 rear to 91 240sx, not sure about others.
I used air tools.
12mm and 17mm sockets, needle nose, 35mm socket for hubs, open rench for 12mm or 17mm. Pair of mechanics gloves and saftey glasses.
Took 2.5 hours with taking pics and taking time with air tools.
First clean up diff and axels with degreaser.
Heres the package.. 5 bolt pattern s13. VLSD.
Drain the old oil...
Add the new oil Penzoil 80-90 gear oil.
raise the car up with 2 jacks and one 1-ton jack in middle of pumpkin. Remove wheels, remove pin, remove center hub bolt 35mm.
Remove the 6 bolts to the axels. 12mm
s13 is almsot the same but the rear cover is bigger but fits perfect.
Remove 4 rear bolts that hold old rear in and the 2 front bolts with jack underneath. It wieghs close to 80lbs.
Lower down rear at an angle then remove both axels remeber wich axel is longer and lower old rear end should fall out.
put s13 axels in long on right small on left, then put s13 rear on jack and rase install 4 blots and then 2 front, secure both axels with the bolts from old rear to all axels bolts. "make sure when doing axel bolts you do every other bolt so it lines up perfect to half shafts to axles or it will not work right on the rode, you will see that there not a perfect fit if its wrong."
Put 4 bolts back in drive shaft and you won...
Go for a slow test.
THE END
Old Feb 11, 2005 | 12:56 PM
onesloweg5's Avatar
Let me know what you guys think i took the time to take pics..
and post thanks...
jeff
Old Feb 11, 2005 | 03:37 PM
Zephyr's Avatar
nice write up! all i can say is that the oil smells like crap!
Old Feb 11, 2005 | 06:45 PM
onesloweg5's Avatar
yes it duz im use to it with my seadoos.... Same smell in our pumps when we put new pump oil.
Old Feb 11, 2005 | 08:58 PM
onesloweg5's Avatar
Also check out my thread about how to take off the knock sensor in no time flat...
jeff
sorry no pics on that one its raining....
jeff
Old Feb 11, 2005 | 10:28 PM
good write up, stickied
Old Feb 12, 2005 | 12:41 AM
Catharsis's Avatar
you left out a couple good steps liek
open trash can
throw vlsd in trash can
or save your self some trouble and buya real lsd
Old Feb 12, 2005 | 02:23 AM
onesloweg5's Avatar
actualy i have the stock lsd wich is going to be a kaaz or cusco lsd while my vlsd is in. No down time. I got it super cheap. Money is going to sr20 first before a $1000 lsd...
NOt trash yet i will get at least 3 months out of it just in time next month sr20...
HAND PICKED 2...
jeff
Old Mar 3, 2005 | 06:32 PM
struck1's Avatar
just swapped the lsd from a 95 j30....i couldnt believe how easy it went...everything just dropped into place...the hardest thing ws lighting a cigarette with the grease on my hands.....any ways thanx for the how to
Old Mar 3, 2005 | 10:18 PM
onesloweg5's Avatar
no prob stay tunned for my ka24de-t kit...
jeff
Old Jul 5, 2005 | 08:42 PM
StillSlow's Avatar
Nice write up!! Wish pics were there,but still very good. Struck1 says he swapped one from a 95 J30, into a '91? Will a differential from another nissan work, i.e. 300zx? Please say yes. I just bought the brake rotors, calipers, hubs/spindels, from a 1990 300zx 5-lug. THey gave me the rear lower controlarms and the axels. Will the control arms fit i wonder but i would really like the DIF. Let me know.
Old Jul 5, 2005 | 09:23 PM
onesloweg5's Avatar
no more pics huh? dam..
check with someone else about all other diffs i used vlsd from s13 and i drift 3-4 times a week from 10 pm till 5 am...
lol
Yes im getting pretty good and i overhall it every month with additive from nissan... very important...
jeff
Old Feb 10, 2007 | 05:45 AM
187cBs13's Avatar
what year and moddle does the s13 vlsd come in se? ec. ?
Old Feb 22, 2007 | 07:22 PM
tehott240's Avatar
this spam **** is pissing me off. ohh yeah good write up it is very usefull.
nismoslyde86
Dec 14, 2007 09:52 PM
twofotisx
Jul 9, 2007 06:15 AM
StanBo
Jul 19, 2005 06:20 PM
leiferik1
Apr 26, 2002 06:44 PM
battlestylespl
Feb 24, 2002 10:59 PM
