DRIVESHAFT Question
Old Mar 30, 2004 | 04:55 PM
Pretzel King's Avatar
Question DRIVESHAFT Question
So I changed the whole rear hub assembly not whats causing the violent vibration. the way the shifter shakes and the rear end to, im thinking it might be the drive shaft. I had a custom drive shaft built for it is it possible that somewhere it came out of balance and thats whats causing it to shake like it is. The other thing I was reading was the perpelar (sorry bout the spelling) shaft in the book it said if its no good it can cause vibrations. At low speeds (under 20 mph) the car is fine but once ur goin the vibration continues.
anyone know the possiblities
1. the custom driveshaft became unbalanced
2. perpelar shaft is no good
Anyone have anyother ideas thoughts possible problems?????
Old Mar 30, 2004 | 07:04 PM
I just heard that its possible that it could be the tranny or rear end..... Do you think thats possible with what i said with this first thread???? I can see the rear end but the tranny???
Old Mar 30, 2004 | 08:30 PM
backlife's Avatar
i had the same problem on my old bmw it turned out to be the driveshaft center bearing was worn and causing the driveshaft to "bounce" up and down, check that out
Old Mar 30, 2004 | 09:00 PM
its a 1 piece driveshaft thats the only reason i didnt think it could be that, u still think its possible?
brainfood
Jun 16, 2004 05:19 PM
Zdrifter
Mar 5, 2004 06:02 PM
boosted98gst
Dec 31, 2003 03:19 PM
Krazyballa3
Jun 22, 2003 08:32 PM
drifterdet
May 1, 2003 07:44 PM
