Nismo Slave Cylinder
Look around fellas. The slave cylinder from Nismo is off of another ride. I would look to see if the part number is the same off of a 300zx or another 6 cylinder car.
That is all they do. Larger parts off another car are better then what was designed for a 4 cylinder.
Your slave cylinder is something to look at when you do the damper box mod and ss line mod.
They are unsafe that is why I mentioned them.
SS line replaces your stock rubber line and does not flex as easy.
Damper box mod makes the pedal feel more direct. Wether you like that or not is up to you. It does not feel as smooth but you have a more direct input on the clutch engagement.
There you are.
There you are.
yektik99
Mar 28, 2005 09:19 AM
