Readjusting the Clutch
Old Apr 29, 2004 | 03:11 PM
ArticDragon's Avatar
Hey, i just got my 240 from the mechanic. He put in a new clutch. the problem is, it catches really late. Before it caught right off the floor, which I liked. but now it catches like almost 3/4 of the way up, and that's too high for my preference. Anyone know how to readjust the clutch so that it catches earlier?
Old Apr 30, 2004 | 03:31 PM
Rouge S13's Avatar
there is a threaded rod that goes from the clutch master cylinder to the top part of the clutch pedal, it is attached to the pedal with a pull pin that is held in place with a cotter pin. remove that and then you will be able to turn the the end of the rod if you lengthen it the clutch will release with the pedal higher if you shorten it the pedal will release lower. if it sounds confusing just look under your dash youll get the picture.
boricuajr
Oct 11, 2004 10:54 PM
haipho123
Jul 25, 2004 11:15 PM
cfin3
Apr 3, 2004 03:39 PM
Ray240CA18
Sep 18, 2003 09:58 AM
