Synchros?
Old Aug 20, 2006 | 09:44 PM
Synchros?
How likely is it that both my 1-2nd gear synchros and 3-4 gear synchros went out at the same time? The transmission has the problem where i have to be almost stopped to get back into first and it now grinds (sometimes lightly, sometimes a little harder) going into every gear but reverse and 5th. When I double clutch it shifts better, but i dont have to rev-match to get it to shift fine, the RPMs just fall to 700 and it shifts fine no matter what the speed is. How likey is it that i just need tranny fluid? The problem started lightly with third gear and now all the gears do it on every shift. Synchros arent something I want to tackle, but where could I buy them if i have to. I searched autozone's website and they dont have them. Neither does Courtesy Nissan. Do I have to go to the dealership?
Old Aug 23, 2006 | 05:04 PM
re037's Avatar
first gear lockout... dont force it
Old Aug 23, 2006 | 07:39 PM
bennieb's Avatar
have ya checked the clutch master and slave cylinders?
Old Aug 23, 2006 | 08:21 PM
epp_b's Avatar
bennieb has a good point. If your clutch isn't disengaging properly, grinding gears could be a sign of this. It makes a sense that your reverse gear isn't griding because the reverse gear is never synchronized. Not sure about 5th though, I'm not a mechanic.
Old Aug 24, 2006 | 09:17 PM
nismo24 owner's Avatar
have you changed your gear oil? my 240 had been doing the same grinding i went to the sports car only shop by my house and they sugested red line full synthetic gear oil (mt-90) i changed my gear oil and my gears go in perfectly(these 240's are prety old and alot of people neglect to change their gear oil)
Old Aug 24, 2006 | 09:19 PM
P.S. changing your diferencial oil might be a good idea 2
Old Aug 25, 2006 | 05:17 AM
Yeah I bought some royal purple, but my drain plug is stripped... i gotta get on that
Gronde240
Apr 8, 2007 10:45 AM
BlackEnigma
Oct 28, 2005 04:12 PM
