vibration at low and high speeds
Old Dec 8, 2003 | 11:46 AM
dkdeleon's Avatar
can any one help, Man i am getting vibration in the rearend at low to stop. it feels like a knot in the tire but its not.
I jacked up the rear and put it in gear and looked for any signs of vibrating in the drive shaft but did not see any. I could feel it vibrating when i had it jacked up and in gear , free spining the tires.
HELP ANY ONE
Old Dec 11, 2003 | 11:17 AM
dkdeleon's Avatar
come on guys, cant anyone help?????
Old Dec 11, 2003 | 05:41 PM
Re: vibration at low and high speeds
HELP ANY ONE
Do you mean, you had the car running in gear while jacked up? or just free-hand rotating the wheel?
Old Dec 12, 2003 | 05:11 AM
Sil40_Mayhem's Avatar
try going to a tire place and see if one (or both) of the rims are balanced and not warped.
Old Dec 12, 2003 | 02:12 PM
dkdeleon's Avatar
I had it in drive while it was on jack stands.
and it isnt the tires or the rims.
Old Dec 13, 2003 | 09:51 AM
subframe loose?
Old Dec 13, 2003 | 12:17 PM
dkdeleon's Avatar
not that I know of.
Old Dec 14, 2003 | 11:46 AM
ok....
- not driveshaft
- not wheels
- not tires
- not subframe
...maybe the diff is shot?
Old Dec 14, 2003 | 06:46 PM
kramsuey2268's Avatar
could be warped brake rotors. Mine had this problem and my car had a good shake to it. Especially when applying the brakes.
Old Dec 14, 2003 | 10:48 PM
dkdeleon's Avatar
it doesnt shake when i brake, only when i drive from 0-5 mh and then again at 65-75 mh it gets worse.
Old Dec 16, 2003 | 02:54 PM
drnovascotia's Avatar
well @ 65-75, that means you need an alignment. when did you have it done last?
The whole shaking @ that slow, is it coming from the front or rear? Normally shakes like that when that slow are from the engine, not the wheels. Happen when you are turning? just going straight, or what? very interesting.
Dr.
Old Dec 16, 2003 | 11:44 PM
I've run out of ideas for this one... I still think it's suspension somewhere...
Old Dec 18, 2003 | 10:11 AM
...did you check all your bushings for play?
Old Dec 18, 2003 | 01:01 PM
dkdeleon's Avatar
I found out what it was.
It was the front part of the drive shaft, it has a slite wable.
thanx for all of your help I went back and double checked everything and found the problem.
once again thanxxxx
fast240
May 8, 2004 11:43 PM
mjk
Mar 9, 2004 10:50 AM
silvia180SX
Jan 27, 2004 07:41 AM
180SXcoolguy
Mar 7, 2003 06:11 PM
