2wd or 4wd?
Old Feb 6, 2004 | 09:55 PM
Driftin_24O's Avatar
2wd or 4wd?
i am going to swap a rb26dett into my 1990 240sx and i was thinking "should i convert it to a 4wd?"then i heard u lose speed on striaght-aways.is this true?or do u gain speed?what should i do 4wd or 2wd?
Old Feb 6, 2004 | 10:01 PM
tommyboy's Avatar
Dude, I hope you are rich. The RB26 will barely fit into the usdm 240 chassis. If you do install this, put on a rb25 transmission that is rear wheel drive.
Old Feb 6, 2004 | 10:43 PM
Do you know how much work(and money and time)will have to be put into a 240sx in order to be 4WD!? Pointless to me, if you really want to do the RB26 swap then check out mckinneymotorsports.com You need to buy a RB25 oil pan and RB25 trans and possible custom driveshaft in order to fit and work properly.
Old Feb 7, 2004 | 02:48 PM
dekand's Avatar
if you have the money and the know-how why not its your money ... and we'd all LOVE to see it happen at least i would... but rwd rb25 will suffice for my needs
Old Feb 7, 2004 | 08:33 PM
93RPS13's Avatar
you may as well buy a skyline R32 GTS-4 or GTR, if you want AWD
Old Feb 7, 2004 | 10:40 PM
Old Feb 9, 2004 | 07:18 AM
Sil40_Mayhem's Avatar
x2 seriously, this has been discussed before. the S chassis was NEVER intended to have AWD/4WD. if it was, it would have been already. plain and simple. and for the buttloads of cash it'll take to make that happen, u'd be better off getting an R32 GT-R from Motorex or something. unless u just wanna do it for the 'cool' or 'different' factor...
Old Feb 9, 2004 | 07:29 AM
jonpowell's Avatar
You will need to have a complete set of front suspension custom built to accomidate the ft drive axles, not to mention possibly notching and reinforcing the frame rails to allow the axles to pass. I was looking into this and decided that the 240 is not a good candidate for the AWD setup.
Old Feb 11, 2004 | 06:22 PM
rps13VEk's Avatar
So there are RWD transmissions that fit on the RB26dett ?
Old Feb 11, 2004 | 06:23 PM
Catharsis's Avatar
ys from the rb25
Old Feb 11, 2004 | 07:24 PM
^^^ The RB25 trans fits on the RB26, and is needed. Also the RB25 oil pan is needed
Myke Hype
Nov 1, 2006 10:39 AM
