Anyone With A Ca18det Swap Read!
Old Nov 14, 2004 | 02:11 PM
SLOazzEPhatch's Avatar
I have searched and searched and there is no real concrete good or bad on this swap. so i have a few questions:
Was it easy? I have swaped Honda before. Will it be equivilent to a b18 in a EG?(if you know what i am talking about )
How much was the swap? and who did you get it from? I don't wanna get ripped off on the price.
What is the redline on a stock ECU?
What kind of HP can you push on the ca18det? I have heard the you can't get much past 300 with replacing the headgasket and possibly even head bolts.
What kind of MAF do i need to use?
Old Nov 14, 2004 | 09:24 PM
sr20hardbody's Avatar
call intercrew auto salon since you are in dallas tx 214 575 6288
Old Nov 15, 2004 | 04:33 PM
You mean InterPOO?! I don't want to talk to anyone there. They tried to screw mw on a spoiler for my EP, and i personally am scared to let them even touch either one of my cars.
Old Nov 16, 2004 | 06:51 AM
srslider's Avatar
I know a couple of guys here that have done the swap, pretty straight up from what I understand. Don't really know about the wiring or what MAF you should run though
Old Nov 16, 2004 | 11:09 AM
4984 5fsdskfvjdsntr4's Avatar
Banned
My friend and i did the swap. Its pretty simple, just make sure u get everything u need before hand and maybe an extra coilpack incase one is bad. The wiring is harder then the actual mechanical.
Stock redline is about 7K, i dont remember exactly cause i only ran the stock ecu for break in. I have an ND stage1 chiped ecu. Got the chip from Ebay, verygood(alittle expensive). Tell them what rev limit u want and what u r running ie turbo, maf, injectors and they tune it for u. I have mine at 7,200 . He was goin to do 7,500 but i wanted it alittle lower for drifting purposes.
I dont know anyone in Tx to get the engine from. When i get my BOV this weekend and run better intercooler piping(im using muffler shop right now) I figure ill be at about 200 to the wheels. Gonna take it to the dyno soon.
* IF u got a question just PM me or check out ********.com they have alot of ca owners there.
Old Nov 16, 2004 | 04:33 PM
i am sure i will be PMing you very soon.
Old Nov 16, 2004 | 04:35 PM
Who do you know over there?
Old Nov 16, 2004 | 06:42 PM
Banned
Also the easiest is if u get the ca18det maf, but alot of ppl say that u can use the SOHC KA maf by just switching the wires.
Also if u get the ecu tuned, then u can use what ever nissan maf u want(ie 300zx)
Old Nov 17, 2004 | 01:46 PM
rkcarguy's Avatar
Anyone who get's a CA18 pull your pan and retorque/locktite the rod bolts. They are suseptable to coming loose and causing a rod knock-eventually the rod cap will just fall off
Old Nov 18, 2004 | 08:07 PM
had this happen to you before?
Old Nov 19, 2004 | 07:55 AM
Banned
no it hasn't and i hope it doesn't. knock on wood.
Ive only had the engine about 1 month now.
Old Nov 20, 2004 | 10:46 AM
rkcarguy's Avatar
Yes I have had one warranty return of a CA that a rod cap came loose, and we had another one way back when we were just getting loose engines that had the same problem. The CA rips though otherwise there's one in town that pulls right with the SR swaps.
Old Nov 20, 2004 | 01:53 PM
well it is good to hear that they can pull with SR swaps. How much can you get a ca18det swap for rkcarguy? shipped to TX?
Strychnine
RB
144
May 12, 2009 01:39 AM
jray0909
Jul 22, 2006 08:52 AM
th3br4d
Dec 2, 2005 04:40 PM
anubis
Feb 2, 2004 10:12 PM
DeRaNgEd
May 30, 2002 07:39 AM
