boost problem
Old Jul 1, 2004 | 06:50 PM
Ricky240sx's Avatar
boost problem
I just intsalled the Apexi AVC-R boost controller and went out for a run, At 1.00 boost with 55 duty which is 14psi's the guage will only read 10psi. I tried everything but it won't boost pass 10? any ideas. I really feel like it boost 14 but both Guages are reading 10psi.
Old Jul 3, 2004 | 06:29 PM
89s13drifter's Avatar
Any boost leaks?? Are you running the boost gauge line and boost controller line at different spots?
Old Jul 5, 2004 | 10:25 AM
Ricky240sx's Avatar
My boost controller is off the wastegate and my gauge is on my bov
Old Jul 5, 2004 | 11:02 AM
rkcarguy's Avatar
If your BOV is set too soft it might bleed off some of your boost, but if your other hose is connected to the BOV(small one that attaches behind the throttle body, usually to map line) it should hold it shut until you shift.
AZdrifterS13
Jan 13, 2007 01:32 PM
project180sx
Jul 28, 2006 10:21 PM
b0rdin4life
Feb 14, 2006 10:53 PM
uvamosk
Aug 12, 2005 07:31 PM
drf3rsmok3on3
Jul 31, 2005 03:24 PM
