Boost on an RB20
Boost on an RB20
What is the most boost i should run on a stock rb20? i searched google and came up with either 10 or 12 psi. who has run 10 or 12 and how much of a difference was it and how reliable will it be?
10PSI is stock so it should be very reliable
12PSI is where I would sit with the stock turbo unless you want to throw the turbine wheel ouot t he muffler & possibly suck chunks of ceramic back into your cylinders.
This is no urban myth, it DOES suck chunks back inside and shred your cylinder walls. It may not happen for a while, but I guarantee you, at some time, that around 14PSI your wheel will come off & shatter.
That is a complicated question that depends on piping size, turbo size, turbo CFM at different pressures, injector size and your ability to alter the fuel/ignition maps.
PSI isnt a ameasure of the quantity of air in your intake tract. PSI is a RESULT of the quantity, not the measure. You need to figure out your power goals, decide on some injectors to reach your goal, an ECU that will allow you to run those injectors and THEN choose a turbo that will push the CFM needed to maximize the injectors.
A larger turbo will force more air at the same PSI than a smaller less effecient one.
You have alot of decisions to make before you pick a 'PSI" to push. Honestly PSI is a relative term that hahs nothihng to do with power level. 15 PSI on a 3/4' pipe is less than half the air of 5PSI on a 3" pipe
ohh ok, i am planning on runing the high output rx7 plugs, and i know a shop that can reprogram the stock ecu. I plan on upgrading to a t3/t4 hybrid. sorry if i leave a lot of stuff out this is my first turbo motor and google searching leaves alot of stuff out.
I ran 10psi before on the stock setup with just 3"down pipe and exhaust. It made 186hp at the 10psi. Then I installed my boost controler and put in my PFC and set the boost to 12psi and walked away with 213hp. The PFC was untuned so I don't think it made that much of a diffrence over the stock ecu. The stock ecu didn't run as rich as the pfc did.
