CA swap on 2 cyl HELP
Old Oct 2, 2005 | 05:06 PM
240pwr91's Avatar
Unhappy CA swap on 2 cyl HELP
somebody plz explain this 2 me. i have 125psi compression, spark, fuel, correct timing, and a ca18 swap in a 91 coupe that runs on only 2 cyl. its like i have half a motor. plug in the injectors and it backfires like a machine gun i need help. some local technitions in the area think it could be the eccs, got a different one in the mail right now.
Old Oct 2, 2005 | 05:10 PM
PNG's Avatar
PNG
Just guessing here, since I wouldn't know a CA18 from an AR-15, but how about the time-honored "distributor 180 degrees out of phase"?
Assuming, of course, that there is a distributor in the first place.
Old Oct 2, 2005 | 05:13 PM
nsn240's Avatar
^yea, check that... also, runing your car while those two cylinders arent workin isnt a very good idea. Check that you have the right spark plug wires going to the write plugs, and that the injectors are OK. may have something to do with a screwy ecu also
Old Oct 3, 2005 | 01:34 AM
iroc07's Avatar
also check to make sure you dont have a pinched injector wire or pinched coil wire, that will create problems like you described and I have seen it more than once on JDM motors from shipping and moving them around.
Old Oct 4, 2005 | 12:04 PM
240pwr91's Avatar
my injectors are pulseing and they hold pressure so i know theyre not leakey or fauty. i already flipped timing and it made it worse so i put back. new plugs with working coilpacks. ?. im so frustrated with this bull im about to pay a shop to do it
LiveSideways
Jun 10, 2006 02:40 PM
420xs
May 21, 2006 07:12 PM
nissan101
Aug 8, 2005 06:30 PM
leiferik1
Oct 13, 2002 08:45 PM
encasemyheart
Sep 6, 2002 02:20 AM
