Is this a decent place to buy a Sr20Det
Old Mar 16, 2005 | 10:25 PM
d_preuss's Avatar
I have been looking for an sr20det s13 to put in my 90' 240sx for a little over a month. I had decided on getting it from phase2motortrends, but they will not have another engine soon enough. I did find an sr20 for fairly cheap from www.japandomesticmotor.com is this a good place to buy from? I was planning on doing a complete rebuild also and I was wondering what pistons and connecting rods are good. Also, where is a good place to order them. Thanks for your help. -Derek
Old Mar 28, 2005 | 08:11 AM
KuhnDawg's Avatar
I'm in the process of getting an s14 front clip from them right now, its due to be here by the end of april. Ill let you know how it goes. The main reasons i went with phase2motortrend were because they are registered through the bbb (and have a good rating), they gave me 100 dollars off the total cost for preordering and they offer a basic install package that if you buy and engine through them they will sell you for 500 dollars:
NEW SR water pump
NEW NGK Platinum Heat Range 7 Plugs
NEW 3pc turbo gaskets (exhaust, inlet, outlet)
NEW valve cover gasket
NEW spark plug cover gasket
NEW OEM Nissan SR20 Upper/Lower radiator hose
NEW OEM Nissan SR20 thermostat
NEW 3pc drive belts
NEW OEM Nissan Oil Pan (replaced often dented pan)
NEW OEM SR20 Nissan oil filter
NEW OEM Nissan Z32 fuel filter
NEW K&N style air filter kit
NEW Megan 3" stainless downpipe
(market value of all this stuff is about 750 bucks,
plus its all good stuff to replace when doing a SR swap)
Old Mar 28, 2005 | 11:34 AM
cbae123's Avatar
well my motor arrive japan domestic and I will be looking at it in a couple of days and let you know what the condition is.
Old Mar 30, 2005 | 11:13 AM
98cwitr's Avatar
hell for $1900 thats a steal...but the website is kinda confusing...it says on the left "The Motor" followed by the engine code and then the price ($1900)...but on the right under "Stats" it lists the tranny, ecu, harness, etc etc. are all of the things listed included for the price or is it 1900 just for the engine itself? And the redline on a rb and the VG is NOT 8900 rpms and correct me if im wrong but the CA18DET (88-90) had 170 hp...they list 135 hp
Old Mar 30, 2005 | 05:48 PM
rapanett's Avatar
The motor I purchased from them ran fine after I spent a lot of timing fixing little things and cleaning it.
This is how they said it was packaged in Canada before shipment....
This is how it showed up at my house...
* No ECU was included
*I had to argue with them to send me a beat up SMIC with no bolts and no piping except for the core and two side pieces.
*The Throttle body was bent and not usuable
*The CAS was cracked and not usuable
The only positive thing I can say is when my friends and I got the motor cleaned and installed it ran really good.
Old Apr 4, 2005 | 09:21 AM
twelvea's Avatar
wow that sucks. Did they refund you anything?
Old Apr 4, 2005 | 03:28 PM
rapanett's Avatar
They did not refund anything. They did send me a beat up smic with no piping and no bolts though.
Old Apr 7, 2005 | 06:33 AM
98cwitr's Avatar
i got a question: How did you get ahold of that pic from the shop in Can?
Old Apr 7, 2005 | 11:19 AM
rapanett's Avatar
The owner of the company personally took it and e-mailed it to me. why?
Old Apr 9, 2005 | 01:48 PM
JDMxDrift's Avatar
I do not suggest buying any engines or clips outside the US. Sure prices are really cheap, but you'll make up the difference in replacing all broken parts. A lot of the time bad things happen and if the replace parts it takes longer because its gotta come from canada. And also, shipping is way expensive. A good example is FlashOptions.com... great prices, but have not heard one good thing about them. Try to find a shop close to you to get a motor.
Old Apr 9, 2005 | 04:17 PM
rkcarguy's Avatar
I wish people would read the "used japanese engines" post stickied in this section. Ahh yes flashoptions......great prices, if you actually get anything.
Old Apr 9, 2005 | 04:42 PM
JDMxDrift's Avatar
haha, i concur
Old Apr 11, 2005 | 08:38 AM
98cwitr's Avatar
just curious.
Old Apr 11, 2005 | 12:45 PM
Joel SX's Avatar
So were can I get some clips at reasonable price? I'm looking for an rb25 or better yet an rb26 engine, but everybody wants to sell those SR20s. Were can i get them?
Old Apr 11, 2005 | 10:33 PM
JDMxDrift's Avatar
why do you want an RB25 or RB26?? What do you plan on doing with your car??
fyneyoungstunna
May 25, 2005 05:58 PM
shane_lxi
27
Mar 3, 2005 09:22 PM
pooptown
Nov 20, 2004 09:51 PM
Aniki_Andy
Oct 4, 2004 06:14 AM
nemesis
Nov 24, 2002 10:27 PM
