KA24DE in 89 240?
Old Apr 16, 2003 | 03:17 PM
silvia180SX's Avatar
KA24DE in 89 240?
I had a 91 240SX Hicas and I was wondering how much work it would be to take my drivetrain and put it in an older 89 240? Has this been done before, and does someone have notes?
Old Apr 16, 2003 | 04:27 PM
I'm with Stupid's Avatar
It should all bolt up assuming both have or don't have abs. Because the abs equipped cars have a drive shaft about an inch shorter to make room for the sensor.
Old Apr 16, 2003 | 06:52 PM
My 91 had ABS, my 89 I just bought doesn't. Can't I just use the driveshaft from the 89?
Old Apr 16, 2003 | 07:58 PM
Yeah, if you use the '89's differential.
Old Apr 17, 2003 | 10:16 AM
Will the 89 diff work with the rest of the rear hicas suspension and subframe? I know that sounds stupid but I already sold my 91 rear end thinking I wasn't going to use it.
Old Apr 17, 2003 | 11:22 AM
The diff shouldn't be a problem. Should of kept that LSD though.
Old Apr 18, 2003 | 01:00 AM
Uhh. yeah I know, I'm kicking myself for that one. Another question though. Since my car was a Hicas can I swap any of that stuff in my rear sudframe as well?
Old Apr 18, 2003 | 10:23 AM
You should be able to swap anything you want over. I bet you could put your HICAS system in if you swapped over all your lines.
Old Apr 18, 2003 | 08:16 PM
Even with a stock 89 diff?
Old Apr 18, 2003 | 08:33 PM
The diffs are the same except for the open or limited slip action.
1991se240sx
Jul 31, 2009 09:58 PM
Indolent
Sep 3, 2006 02:51 PM
Purple240
Mar 18, 2006 01:31 AM
YangpaNemsay
Jul 20, 2004 01:35 PM
DCTperformance
Mar 13, 2003 12:49 PM
