KA24E for a KA24DE
Old Nov 8, 2004 | 12:00 PM
snowboard240sx's Avatar
KA24E for a KA24DE
I bought my car a week ago and i had a sticky cam shaft and now there is a hole threw my engine block.
Instead of dropping 6 grand on a SR20DET with install and all that crap im gonna spend alot less and just put in a new KA24E or KA24DE, i am just wondering if anyone can tell me if in a 1989 240sx if everything will mount up properly when i swap my KA24E for the KA24DE Thanks alot guys
Old Nov 8, 2004 | 12:50 PM
Skiboard06's Avatar
Most stuff will mount up such as; motor mounts, driveshaft, shifter. Some important things wont match up though. Including; your sohc tachometer wont work, wiring harness' need to be re-wired, and power steering will be an issue. Im sure i forgot other things I will try to think of other things.
Old Nov 8, 2004 | 02:40 PM
SR shouldnt cost more then 4k including install. That is for a basic set up
Old Nov 8, 2004 | 03:22 PM
Thanks guys for ur replies, its helpful for me, i went earlier today and checked it out, to get the sr20det into my car its around 4500 with labour and parts, but its not worth my time as i am 17 and only make 10 bucks an hour. so instead im sticking with my ka24e, unfortunatly the place i go to is having trouble locating a rebuilt one and i am going to have to pay for a rebuil 2500 bucks with a used block, owell **** happens
Old Nov 16, 2004 | 10:47 AM
Yangya's Avatar
so have you already swap your engine yet snowboard?? cause if you have, i need some help from you. i'm doing the same thing and i have everything into my car. the only thing i have left is just connecting the harness? you think you can help me out?
Old Nov 17, 2004 | 09:15 AM
sorry i havent done the swap yet, im picking the engine up this sunday and i am not personally doing the swap because i need it done asap and im getting some other stuff done to the engine....but im sure you can find out about the wire harness....try www.neo240sx.ca ive gotten som good info from them and u can also try www.son240sx.ca
S13freak
Jun 21, 2004 10:27 AM
Tempest
Feb 12, 2004 10:31 AM
spliffstar
May 9, 2003 07:42 PM
xriz
Nov 22, 2002 02:42 AM
spliffstar
Oct 7, 2002 06:23 PM
