Ka24e removal help
Old Mar 28, 2006 | 01:25 PM
SoloDefcon's Avatar
Question Ka24e removal help
Im just wondering what needs to be done in order to get the engine out, without cutting the wiring harness. It seems impossible to disconnect some of the plugs. Help is greatly appreciated, Thanks
Ben
Old Mar 28, 2006 | 01:31 PM
Just remove everything that goes from the chasis to the engine, it takes some time but its not too hard. There should be no need to cut the harness at all.
Old Mar 29, 2006 | 11:30 AM
SoloDefcon's Avatar
^^So do i need to basically take out the front dash, disconnect the harness from the ecu, and pull it through the firewall, or is this a copmletely different way?
Old Mar 29, 2006 | 11:38 AM
You can just disconnect the harness from the engine and pull it, theres no need to remove the dash and stuff. What engine are you swapping into the car?
Old Mar 29, 2006 | 11:46 AM
SoloDefcon's Avatar
Im not planning on swapping, im just taking out the motor to use for parts, or possible rebuild. The car is beat (not even worth fixing) and planning to use it as a parts car or part out, well see how things pan out.
Old Mar 29, 2006 | 11:54 AM
You should be fine then just disconnecting all plugs, A/C lines, fuel lines, and pulling it. Once you start the process you'll find thats it alot easier than it even looks, shouldn't take too long at all.
Old Mar 31, 2006 | 08:25 AM
SoloDefcon's Avatar
Alright im having some trouble...The part of the wiring harness that comes out from the firewall (passenger side), i dont see how else you can take that out without taking out the front dash...ill take pics soon.
Ben
Jay_240sx
Jan 4, 2008 11:18 AM
servo09
Nov 15, 2005 03:55 AM
Choppa'
Apr 3, 2005 01:25 AM
Krysis
Jul 12, 2004 12:39 AM
