mystery hose on srclip
Old Jul 25, 2004 | 02:00 PM
juggalo_240's Avatar
ok i got my sr clip and i was cleaning all the grime getting ready to pull the engine to do the swap when i noticed something conspicously missing...but im not sure what...there's a hose that leads toward where the air filter would sit but it just ends with a hose clamp and it looks like it attached to something attached to the front left shock tower but that part has been unbolted...any one know what it could be? the hose comes off somesort of solenoid assy bolted to the left side of valve cover...thank
Old Jul 25, 2004 | 04:02 PM
rkcarguy's Avatar
Hi, the stock airbox had a fitting for this, it was some sort of crankcase recirculation setup. Most of the swaps I've seen that have aftermarket filters don't have the fitting. Some just leave it open and hanging, but I'd put some kind of little filter in it, a chunk of air cleaner foam, or something. Won't upset anything the engine won't know it's not hooked up.
Old Jul 26, 2004 | 04:25 PM
thanx i was also wondering if it maybe was a egr setup?
Old Jul 26, 2004 | 09:50 PM
rkcarguy's Avatar
It might be, but the EGR has to die the metal tube from the downpipe won't clear the steering shaft. I guess it's like EGR is draws the gases and stuff from the crankcase and feeds them into the intake instead of just venting them.
Old Jul 27, 2004 | 07:44 PM
would that ba a bad place to put an egt sensor???i could make a real perty adapter to plug the hole
Old Jul 27, 2004 | 08:08 PM
rkcarguy's Avatar
not really, it's far enough from the turbo it should be fine
Old Jul 27, 2004 | 08:20 PM
hey rc if i make a bunch of the adapters wanna sell em for me???
Old Jul 27, 2004 | 10:24 PM
rkcarguy's Avatar
I'd just put them on ebay anyone can do that.
Old Jul 31, 2004 | 03:09 AM
areitu's Avatar
I speak chinese and ride a bicycle. :P
USMCDrifter
Oct 3, 2008 11:28 PM
automagic
Aug 6, 2005 07:02 AM
EAGLE 5
Nov 28, 2003 06:43 AM
yomny
Aug 5, 2003 06:23 PM
houston
May 31, 2003 08:05 PM
