NEED HELP!!!! SR20DET won't crank over
Old Jun 19, 2003 | 02:15 AM
beefcake6681's Avatar
Exclamation NEED HELP!!!! SR20DET won't crank over
I need help! I just finished with the install of the SR on my S13 and finished all the wiring, but it won't crank! When I turn the ignition to prime it, I just hear the fuel pump and starter, but it won't crank! I don't know what to do.
Old Jun 23, 2003 | 08:22 PM
Monkey Force's Avatar
Is it at least trying to turn over or is there just the "click" sound?
Double check your battery and all of your grounds.
Old Jun 24, 2003 | 12:15 PM
wushu4u's Avatar
Same thing just happend 3 days ago on a friends Lincoln Town Car...she asked for my help so I came over and figured it was the battery...jump started it and it turned over...then she turned it off later and was stranded...damn fords.
Old Jun 25, 2003 | 01:57 PM
BuudWeizErr's Avatar
Check the harnesses under your fuse box, up by the battery. Mine did the same thing, and the problem was finally troubleshot down to a harness that hadn't been plugged in.
Old Jun 25, 2003 | 02:46 PM
Talking
Thanks guys I finally got it started. It turned out to be a bad ground at first. When we fixed the ground problem, it would crank over but no spark. Then we found out that the CAS wasn't fully pushed in, so after we did that, it fired right up.
rblover
RB
Jul 13, 2008 04:48 PM
copycon
Jan 27, 2007 08:11 PM
Rusker
Aug 24, 2006 10:53 PM
bikeboy600
Jul 5, 2006 01:14 PM
redline88
Jan 17, 2006 09:31 AM
