rb20det modifaction
Old Jul 28, 2003 | 01:08 PM
DC2R Munky's Avatar
At the risk of getting flamed...has anyone seen a detailed RB20DET install guide on the internet? I am trying to finanically plan for the swap, now that I finally have a car! If there isn't a guide on the net, there will be after I finish my swap!
The other alternative is asking a bunch of questions after I do a buttload of research!
Nismo, did you take any pictures of your install? And when you say the car handles differently, how do you mean? More prone to over/understeer? Different weight transfer characteristics? Help is appreciated, esp considering I am very close to buying a front clip.
I plan to strip some weight, do some weight relocation (battery, etc), then use corner-weighting to determine spring rates. Wouldn't this make for a decent-handling car?
Old Jul 28, 2003 | 01:14 PM
Nismo241's Avatar
I have a somewhat detailed 'guide' on the zilvia.net forums. But yeah I have a photo album with like 160 some odd pics of it. It's heavier in front and you can tell, but it's not bad, it pushes a little but more when it's wet out, but no big deal.
EDIT*** oops for got the link to the pics http://www.imagestation.com/album/?id=4290466361
Old Jul 28, 2003 | 01:16 PM
Nismo241's Avatar
Originally posted by -HyJynX-
does the engine sit lower and closer to the firewall? im thinking about trying this out and if it doesnt work then ill go for the -UH- mounts.
The motor sits about an inch and a half away from the firewall measured at the cam covers. And the crank pulley sits a fist length away from the radiator.
Old Jul 28, 2003 | 02:03 PM
hood clearance nismo?
Old Jul 28, 2003 | 02:17 PM
Nismo241's Avatar
I coudl have gotten away with cutting a small portion of teh skeleton out, but I cut out all of it instead. Now wishing I hadn't but you would only need to cut out a small portion of it.
Old Jul 28, 2003 | 02:20 PM
0k i took a look at ur photo album, nice. Ill be starting on mine soon hopefully
Old Jul 28, 2003 | 02:46 PM
Nismo241's Avatar
Well good luck and if you need it, IM me or E-mail me any problems you run into.
Old Jul 28, 2003 | 03:02 PM
k0ol thanks, im hoping i dont run into any problems..or dont run outta money
Old Jul 28, 2003 | 10:35 PM
SHIFT_Lock's Avatar
the 8 dollar brakets will set the motor back but won't lower it.
the uh mounts were made shorter than the original mounts.
and they use the stock KA isolaters.
hood clears no problem. no mods are needed to the car at all.
and i also am available if any questions are need to be answered.
rb20s13@yahoo.com
NightXCZ77
Nov 6, 2009 10:08 AM
Driftin180SX
Jan 23, 2005 12:19 AM
kaos
Jan 19, 2003 12:16 AM
NightXCZ77
21
Jan 17, 2003 11:32 PM
keithtau
Dec 15, 2002 02:33 AM
