RB25DET Turbo Tech.
Old Mar 12, 2004 | 03:00 PM
dick's Avatar
RB25DET Turbo Tech.
I am getting a RB25DET and I am wanting to buy the Garrett T28 Turbo. The T28 turbo is a T25 turbo housing with a 16g turbine. I read it is good for up to 380hp at 21lbs. of boost. I was just wanting to know if it would be safe to run 21lbs. of boost on a skyline engine, without blowing a head gasket or damaging the internals. I heard that the RB25DET engine has a lot of potential and it supposively can support up to 450hp on stock internals. I would only run 21lbs. on the race weekends and maybe 10-15lbs. on daily driving.
Old Mar 12, 2004 | 03:02 PM
PROJECTRB240SX's Avatar
the rb25det has a t3 flange so you would have to build a custom manifold.
Old Mar 15, 2004 | 08:36 AM
neoamd's Avatar
I do believe you could send the stock turbo (t-25 right) and have it rebuilt and ported into the FP Big T28.
www.forcedperformance.com
Josh
Old Mar 15, 2004 | 08:40 AM
THE STOCK RB25 TURBO IS A T3 FLANGED T28 WITH PLASTIC OR CERAMIC WHEELS. THESE CAN BE UPGRADED AND FLOWED OUT FOR BETTER PERFORMANCE IF NEED BE BUT A TURBO UPGRADE WOULD BE A BETTER OPTION.
Old Mar 15, 2004 | 10:05 AM
neoamd's Avatar
Sorry for the misunderstanding.
hmm.. Ill look into what can be done to the stocker. Friends!
Josh
Old Mar 15, 2004 | 10:17 AM
NO PROB.... THE RB20DET HAS A T3 FLANGED T25.
Old Mar 15, 2004 | 01:20 PM
240chz's Avatar
not to thread jack or anything but if u had a rb20 could u just upgrade to the rb25 turbo, since they both have a t3 flange?
Old Mar 15, 2004 | 02:44 PM
Yes, but the water and oil lines are different, These will need to be custom. The rb25det turbo is significantly weaker than the rb20det turbo but produces more power with less boost.
Old Mar 15, 2004 | 07:56 PM
240chz's Avatar
oh ok.. thanks!
Couped_up'd
Apr 18, 2009 04:42 AM
240sxFan
Sep 22, 2004 12:50 AM
Zdrifter
Feb 27, 2004 06:59 PM
Simple S13
Jun 18, 2003 12:05 AM
Jonas
May 24, 2003 02:10 AM
