SR20 needs a vss, how hard is install?
Old Nov 2, 2004 | 06:33 AM
kxpedder7's Avatar
I have a 95 240 with a SR20DET and Tranny in it . When the swap was performed, the previous owner did not install a sr20 vss, therefore the speedometer does not work.
How hard is it to install? Is it easily accessable, or do you have to drop the tranny? If anyone has experience with this, I would greatly appreciate anything you know about it.
Also, I was told they were about $100 from a dealer.
Old Nov 2, 2004 | 02:08 PM
jonpowell's Avatar
cake, but it HAS to have a sensor or all the trans fluid would leak out. Probably just needs to be wired in.
You can change it with the trans in the car.
Old Nov 4, 2004 | 09:07 PM
kxpedder7's Avatar
thanks. I will ask him if the original is still in it.
Old Nov 5, 2004 | 05:39 AM
rudee023's Avatar
Make sure he swapped the KA one into the SR tranny as it is calibrated for mph. Unless you are running the kph guage cluster then use the SR one.
Andy781
Mar 9, 2009 09:23 AM
Flip_240Sex
Mar 1, 2006 05:55 AM
240drifter4u
Jan 10, 2005 02:39 AM
phil0315
Southeast
Oct 26, 2004 05:51 AM
rusty420nr
Mar 20, 2003 08:28 PM
