SR20 wiring
Old Feb 3, 2004 | 11:29 PM
Krea2nr's Avatar
SR20 wiring
Ok Im doing an sr20 swap into my 92 coupe, everyone tells me it bolts right in, but when i ask them what i need to rewire they just tell me that they had someone do it for them..uh not to much help there...Can someone tell me what i need to rewire harness wise, and any other complications i may run into during my swap?
Im gonna buy my engine from japanese domestic motors and im gettin an unut harness wit ecu. Should I buy new mounts? Also where can i get some wiring schematics for the sr20? any place on da net? Just tryin to prepare myself for this swap...thanx for the help...
Old Feb 4, 2004 | 12:33 AM
srswap.com, please search. Does is come with ignitor chip? You have all the piping/IC and etc..?
Old Feb 4, 2004 | 04:50 AM
project_427's Avatar
i did my swap myself but i sent my harness to protech performance in tx. they did the harness conversion for $150 all i had to do was hook everything up. i would HIGHLY recomend NOT doing the conversion yourself unless you are extremely experienced with the 240sx wiring system. if you're not you could really screw up your car. and like hyjynx said do some investigating, make sure you're getting everything you need. i bought just the motor and tranny and i spent twice as much in the long run because i didn't have things i needed. do your homework and leave the electrical to the professionals.
Old Feb 4, 2004 | 08:51 AM
Krea2nr's Avatar
Im a tech so wiring is not a problem, yes i do get an igniter chip.See thats one of those replys im talkin bout though.
Old Feb 4, 2004 | 08:57 AM
Krea2nr's Avatar
IC and piping included and all sensors,engine fans, ac compressor, power steering pump, i get all da good stuff...its basically a complete swap
Old Feb 4, 2004 | 09:41 AM
Krea2nr's Avatar
Thanx Hyjynx for that site help answer a few questions
Old Feb 4, 2004 | 10:16 AM
ok cool, just looking out. No prob
Old Feb 4, 2004 | 11:39 AM
element's Avatar
i plan on doing the swap myself when i get my car/engine as well...
and i'd be doing the wiring harness too if it's all plug and play.
did you guy's hook up the wiring right before initially putting the new engine in? or did you guys wait till after the engine was put in? i think it would be easier to reach all the connectors on the bottom if you had it halway wired up already before installing the engine (but i wouldn't know, i've never done an sr swap before)
Old Feb 4, 2004 | 12:47 PM
Me and my friends first did the wiring in the engine bay first, then we put in the engine and hooked everything up. Wasnt tough at all
Old Feb 4, 2004 | 11:22 PM
Krea2nr's Avatar
Hey Hyjynx what wires on your harness did you rewire?.What did it take to do it..how long did it take you
Old Feb 5, 2004 | 01:02 AM
It wasnt on mine, it was on my friends SR. We basically followed what the lil FAQ said on the SRswap.com site said. As easy as that really. We spliced/lengthend all the necessary wires together, then wrapped them and hooked them up. It took us...a good 5-6 hours. It was our first real time doing wiring.
Old Feb 5, 2004 | 09:42 AM
Krea2nr's Avatar
Guess ill do the wiring first seems to be a whole lot easier, did you relocate your battery?
Old Feb 5, 2004 | 10:21 AM
Nope, kept the battery in the front
Old Feb 5, 2004 | 11:33 PM
Krea2nr's Avatar
koo thanx for all da help
Old Feb 6, 2004 | 12:03 AM
No prob
boosted-alty
Feb 15, 2007 12:08 PM
KingOfDrift
Dec 1, 2005 01:25 PM
sik96sx
Sep 1, 2004 07:28 PM
j-z
Nov 16, 2003 03:54 PM
konseiEva
Jan 21, 2003 11:13 PM
