sr is running wrong
sr is running wrong
so im driving and all of a sudden when i accalerate, i hear almost a pop and my car starts driving very wierd. It is like backfiring pretty badly, and as soon as soon as it feels like boost starts to kick in it looses all power, and just bogs. I just the tubes and everything looks alright... any info would be apreciated. thanks
here's my quick way to check timing:
get an extra coil pack offa '95 Maxima and attack a length of spark plug wire to it. Tape the wire to the coil pack to make sure it won't pop out. Remove the coil pack for cylinder 1 and plug the harness connector to your new makeshift coil pack. plug the spark plug wire to the plug. With a timing light (go to an auto store to pick one up for about 40-50 dollars), attach the clip to the spark plug wire, and the battery cables to their proper places. crank the engine and point the light at the crank pully. Timing lights are nothing but strobes that pulse when the plug in #1 fires. You will see a small metal needle above the crank pully, guage where ignition is by what tick mark is lined up with the needle. I think it's supposed to be right behind the 4th mark (16 BTDC). You can rotate the crank angle sensor to adjust timing (the same you would do with a distributor)
Neferdite
Feb 26, 2002 07:19 PM
