sr20 wont run after swap
Old Sep 14, 2005 | 12:07 PM
STEARNZY's Avatar
Angry sr20 wont run after swap
ok i just finished putting in my sr20det into my 91 240sx and im having and issue getting it started. i have gas i have spark all my wiring is good according to like 4 sites i have looked on and it wont go. it turns over but wont go it will backfire once in a while but nothing else
help please
Old Sep 14, 2005 | 03:30 PM
jonpowell's Avatar
Take out CAS/distributor, rotate stalk 180º and reinsert.
Old Sep 14, 2005 | 03:47 PM
2fast4y0u's Avatar
also check you MAF and make sure its not dirty, also make sure its good.
you can un plug the CAS to build oil pressure with out it firing.
if im not mistaking go to heavythrottle.com and they have a trouble shooting guide o get that motor running for ya
Old Sep 14, 2005 | 08:15 PM
STEARNZY's Avatar
k cool ill try that
Old Sep 14, 2005 | 09:25 PM
STEARNZY's Avatar
ok tried it and now it will fire once and then it feels like the engine completely stops, starter and all. almost as if it were going in the wrong direction
Old Sep 15, 2005 | 03:23 AM
jonpowell's Avatar
battery?
Pull all 4 spark plugs & crank it for a bit, might be over flooded & vapor locked.
NismoKAGE
SR
Feb 4, 2011 03:04 PM
240Boogyman
Nov 24, 2008 10:05 PM
rodgozinya
Feb 19, 2006 06:44 PM
CrAcKHeAdBoB
Dec 1, 2005 02:28 PM
