SR20DET Swap Slowly Underway
Old May 18, 2008 | 03:26 AM
91240SXGuy's Avatar
Thumbs up SR20DET Swap Slowly Underway
Well, I finally got SR20DET, S13 Engine, 5 Speed Transmission, Intake Manifold, Fuel Rail, Injectors, ECU, Igniter chip, Uncut Wiring Harness
Throthle Body, Exhaust Manifold, Turbo Manifold, Cam-Angle Sensor
Alternator, Starter, A/C Compressor, Power Steering Pump, Sensors, Clutch kit, MAF and they through in Free LSD Differential, side mount intercooler and piping.
Now I waiting all my up grade goodies, EZ Install Kit with Heater Hose Kit, Radiator Hose Kit, Belts & AIV hole plug, Hot Pipe with BOV flange attached (Blitz must be welded on), Walbro 255 lph Fuel pump with install kit
Autometer Dual Gauge pillar pod, OEM Nissan Oil Filter (going to get K&N instead), FRAM Z32 Fuel Filter, Adjustable Electric Fan Thermostat with surface mount sensor, MAFS Adapter for intake filter, Megan Racing Test Pipe with Gaskets and hardware, Stainless Steel line with block adapter for oil pressure gauge install, ACT HD Street Disk, NGK V-Power Heat Range 6, Greddy LS 2008 FMIC intercool kit with piping, Greddy type RS Blow off valvem DNA Motorsports Manual Boost Controller, KOYO Aluminum Racing Radiator, and Megan Racing B&M Style Shifter.
I can hardly wait to get started..."Patiently Waiting" Grrrrrrr. LOL
91240SXGuy
Jan 20, 2009 12:46 PM
MunsonAuto
Feb 12, 2008 03:30 PM
zako
Apr 24, 2007 10:40 AM
Komedy
Jan 23, 2007 05:37 PM
LaDyInRed
Oct 22, 2004 12:17 AM
