Stalling SR20DET!!!NEED HELP BAD
Old Jun 25, 2003 | 07:20 AM
DrftDmn's Avatar
Ok This is in my friends 92 sentra SE-R we but a red top SR motor in it and it has a really wild idle ( sounds like a monster cam on a V8) And it only runs at full throttle , If you try and go constant speed the car will buck back and forth . If you let it idle it will die , The only thing that didnt work with the motor is The ACC I have no clue what this is , But we used the one from his original SR20DE motor , Im thinking that that may be the problem > Any advive would be wonderfull
Old Jun 25, 2003 | 06:02 PM
Monkey Force's Avatar
are you posistive this is a good motor?
sounds like it could be your ignition....... check plugs, coil packs, igniter
What is an ACC ?
Old Jun 25, 2003 | 09:49 PM
sr20det power's Avatar
acc= automatic climate control?
im guessin here
240smoke
Jul 30, 2008 04:12 AM
dubbs
Apr 10, 2007 08:32 PM
slcmuffinboi
Dec 4, 2005 09:24 AM
1995 240sx
Sep 23, 2004 09:20 AM
cjm93240sx
May 14, 2003 07:59 PM
