What Mass air sensor should I use on my SR?
Old Nov 24, 2004 | 04:01 PM
jbask's Avatar
Hello There, What mass air sensor should I use on my SR? The engine doesn't come with 1. Would the stock KA sensor work? Or should I buy a 300zx sensor? Please let me know. Thanks
Old Nov 26, 2004 | 07:17 PM
doua's Avatar
I know some guy that are using the ka24de and it work fine.
Old Dec 1, 2004 | 06:37 PM
rsmotors's Avatar
stock ka will work fine
Old Dec 2, 2004 | 06:54 PM
drnovascotia's Avatar
300ZX maf if you want big power.
Dr.
Old Dec 2, 2004 | 07:00 PM
Dustbunnie's Avatar
KA24E...the DOHC one won't work, the SOHC one will
Old Dec 3, 2004 | 06:41 AM
TWAN's Avatar
yeah if you have to buy one you might as well upgrade to the 300 zx one.
Old Dec 4, 2004 | 12:40 PM
jbask's Avatar
Cool I will run my ka24de maf! What's is the reason for chenging to the 300zx? Does if handle more boost?
Old Dec 4, 2004 | 04:34 PM
reccakun08's Avatar
not neccesarily more boost but higher horsepower
Old Dec 5, 2004 | 12:07 PM
rudee023's Avatar
You cannot run a dual cam MAF, it has to be the single cam, KA24E off a 89-90. You could upgrade to the Z32 but you will need something to be able to run it i.e. Power FC, SAFC, etc...
Old Dec 5, 2004 | 10:08 PM
TWAN's Avatar
I thought this guy was putting it on a sr swapped 240. Couldnt he use something like a Apexi afc-r to control the air fuel. Or will the motor run fine with the 300 zx MAFS and no type of engine managment.
Old Dec 6, 2004 | 05:59 PM
jbask's Avatar
Opps my bad, I met I would use my sohc (89 ka24e).
Thanks for all you info!
Old Dec 23, 2004 | 02:10 PM
james_s14's Avatar
i just got a z32 maf and i dont have any engine management, all i have are stock injectors and a apex safc2..can i still use the z32 maf with no ecu retuneing?
Old Dec 23, 2004 | 06:43 PM
Skiboard06's Avatar
safc2 is a type of eng management u will just need to up ur injector correction
seanchris16
Jul 20, 2007 12:25 PM
birgir185
Dec 9, 2005 11:26 PM
S14ninja
May 7, 2005 12:25 PM
Driftmonster
Mar 28, 2005 05:58 PM
erothem
Jul 6, 2003 01:11 AM
