240 died i need help
Old Sep 9, 2006 | 06:52 PM
mental404's Avatar
So i was driving up a hill today in 3rd gear,When all the sudden i heard a clunk.My car started shaking and struggling up the hill,so i shifted into 2nd gear and still wasent picking up.I eventually came to a stop put it in first,and tried going the engine reves and moves alittle but then stalls as it seems it doesent want to move.The engine sounds like a go cart and shakes alot,and it sounds like the engine is struggling really hard to stay running like a belt tightened up super tight or someting.Any suggestions the car still starts,rough i may add but deff not driveable.Someone told me it could be my clutch as it was on its way already.So any suggestions,thanks alot.
Old Sep 9, 2006 | 07:07 PM
re037's Avatar
the condition of your clutch shouldnt make your engine run like that.
start with basics:
fuel spark compression
i have a hunch... check timing chain, might have jumped teeth
Old Sep 9, 2006 | 07:08 PM
trevr's Avatar
I'm sure its not the clutch that went on you. A car will still start and idle fine with a faulty clutch.
After the clunk noise, are there any other consistant noises when the car is idling.
Old Sep 10, 2006 | 09:39 AM
mental404's Avatar
ya when its idling it still makes the same noise.Its just a real loud noise and is constant.Once again it sounds like a go cart.Hope that helps.
barcode
Aug 1, 2006 04:24 PM
anonymous_240
Jun 13, 2006 08:40 PM
woofywolfer
Jul 22, 2005 04:53 PM
woofywolfer
Mar 24, 2005 01:07 PM
leiferik1
Mar 1, 2003 06:21 AM
