CEL ON when my battery died..?
Old Jul 21, 2005 | 12:09 AM
woofywolfer's Avatar
My car battery died, and i was middle of no where. So i tried turning the key, on my 5th time my car started, but then my CEL turned on soon after. What's going on?
Old Jul 21, 2005 | 08:12 PM
Sieji's Avatar
Explain, battery died... like no starter moving/engine turning over?
Old Jul 22, 2005 | 01:25 AM
When i turn the key i hear like a grind. It goes EAK. only once
Old Jul 22, 2005 | 06:01 AM
Sieji's Avatar
If it made a grind/twitch noise then....
I'm guessing ur Bendix isn't sitting right on ur starter. The 5 times you tried to turn over ur car nudged the bendix in place til it could turn over your engine.
If your could start ur car, then ur batt didn't die, if anything it might be a lil weak from dry cranking/amp draws
As for your Cel going on and junk like that... prolly some electrical prob when the engine switches from batt to alt... take a voltmeter to ur cigarette lighter and see what's up.
Old Jul 22, 2005 | 04:53 PM
the reason why i think it was the battery is because when my radio is playing and i turn on my headlights or push back the headlight switch for highbeams, my radio will shut off for a second. But thanks for your advice, i'll check up on my car.
mrjchinchilla
Jul 13, 2009 02:25 PM
scooz14
Dec 11, 2007 12:03 PM
Alteus
Nov 7, 2006 03:06 PM
JDMxDrift
Aug 3, 2006 04:00 PM
JDMxDrift
Jul 7, 2005 12:45 AM
