96 240sx stalling
Old Jul 11, 2006 | 12:13 AM
InitalS's Avatar
96 240sx stalling
hi
you guys can anyone help me what you need to do i have an 96 240sx the engine is stalling anyone can help me out what causing the engine to do that thanks..
Old Jul 11, 2006 | 08:15 AM
When does it stall?
Old Jul 12, 2006 | 01:44 PM
Badazz_240's Avatar
Make sure all your intake sensors are connected, spark plug wires are in the correct order, and replace your fuel filter..... (I swapped mine out for a Z32 fuel filter.... can't remember if I noticed the difference or not)
Old Jul 14, 2006 | 11:07 PM
InitalS's Avatar
Is the motor that's is stalling whenever u stop on the red lights all suddleny the engie die off so pretty much that's how is it anyone let me know ok...
Old Jul 14, 2006 | 11:41 PM
Badazz_240's Avatar
does it stall like... you dont have your clutch in when you stop?
If so, try bleeding your clutch... dont know if it will help, but worth a try
Old Jul 15, 2006 | 12:08 AM
InitalS's Avatar
sorry but um.... my 240 is an auto not manul i converting to manul soon after when i slove this problem but yeah so its stalling is it when it does that blacksmoke coming out from the exhaust and i think u have to clean the air fiter and clean ur thortty..
Old Jul 15, 2006 | 08:27 AM
BigVinnie's Avatar
First run an ecu diagnostic. This should be done before assuming the failure of component's that may not be faulty.Diagnostics pulls up any faulty equipment that won't function correctly to the consult, located on the motherboard of your ecu.
Actron code scanner is a cheap diagnostic checker made for OBD1 and OBD2.
You can get them at
http://www.jcwhitney.com/autoparts/B...003519/c-10101
I believe the books are $30.00, and an actual code scanner with voltage detection is around $250...
What you described can be a numerous amounts of problems from egr purging from the temp sensor throwing the wrong voltage. To a IACV that is plugged up from to much exhaust crap. Even your PCV, or maybe even a vacuum line that came lose.
It could just be as simple that you haven't replaced plugs/wires/distibutor rotor at the 30,000 mile check point.
dubbs
Apr 10, 2007 08:32 PM
kingcarm
Jul 7, 2006 11:38 AM
DrftDmn
Jun 25, 2003 09:49 PM
cjm93240sx
May 14, 2003 07:59 PM
Creamyitalian
Feb 4, 2003 08:18 PM
