wierd engine noise
Old May 3, 2006 | 05:31 AM
90sx's Avatar
Exclamation wierd engine noise
whats up guys, so I put a new timing chain, guides, and tensioner, as well as an oil pump on my 1990 240 with 178k on it. It drove fine for a day and then on my way to work it started making a weird noise at idle....the best way to describe it is it sounds like a baseball card going through bike spokes that ch,ch,ch,ch noise. I took my valve cover off thinking mabye it was the tensioner but the chain seems tight,and the tensioner is tight. The car runs fine other than the noise. Someone from work suggested lifters....I don't know it's not really a ticking noise. Any ideas? I hate this car just sitting in my driveway!
Old May 3, 2006 | 09:01 AM
Preston's Avatar
You put the guides back on....that's why.....take them off and check your tensioner....it should go away if it's nothing too bad.
Old May 3, 2006 | 11:30 AM
90sx's Avatar
take the guides off and to make sure the tensioner is working...or take them off totally?....I'm not sure I understand what you mean.....thanks
Old May 4, 2006 | 04:10 AM
re037's Avatar
nissan released a tsb a few years ago. ya dont need the guides. well at least for the dohcs...
Old May 4, 2006 | 04:39 AM
90sx's Avatar
my engine is a sohc.....
Old May 4, 2006 | 02:33 PM
dak2007's Avatar
i just changed my timing chain for the second time today and it makes the same noise. it did it originally too. i found that if you shift at 4k rpm and drive for about 1-2 hours it goes away. i think it's just breaking the guides in or something.
Old May 4, 2006 | 08:13 PM
Preston's Avatar
Don't put the guides on guys. They're not needed. Nissan issued a TSB to remove them. It's ok to not have them on there all they do is cause problems.
Old May 5, 2006 | 05:54 AM
dak2007's Avatar
so how does the tensioner work if there is no guide? i know nissan did a recal or something like that a while back but i thought that was to upgrade the guides.
aaronbaird
Nov 14, 2007 11:03 AM
Driftingkid101
Jun 6, 2005 04:20 PM
ryan15
Feb 18, 2004 09:51 AM
kboonhower
Jun 10, 2003 09:41 AM
jr1955
Mar 6, 2003 10:09 AM
