For the CA18 Guys who want 500hp
Old Feb 28, 2006 | 11:07 PM
silviasichigo's Avatar
This is the TEX modify Drag SX-R
For thoes that can't read japanese I will translate.
The yellow Box "Drag tuning Concept" Just a little history for them they can easily build 700hp SR so they wanted to tackle a CA, They are the fastest CA in Japan in 2000.
Tuning Specs
CA18DET/1845 Tomei pistons
84mm Trust Connecting Rods
STDShagai ummm they Used a STD Crank
Tomei Cams 280in/280ex
They used their own big Valve system
GT-R type Vavle springs,
HKS headgasket
They made their own Fuel system with 700cc main injectors and 440cc x4 additional injectors and controller
CA18 16 it harness adaptor with a S14 Power FC
GT-R radiator
Greddy T67-25G turbo
Stock Intake manifold
Greddy 3 core FMIC
HKS EVC (boost controller)
Greddy Racing wastegate
Their own design exhaust manifold
Greddy Muffler modified by TEX
OS giken Twin Plate clutch
Trust 6 speed Dog mission
Nismo LSD 4.3final gear
Apex Drag dampers
This car dynoed at 500ps at the wheels little less than 500hp boosting 1.9 and has full boost from 5000-9000rpm Ran a 10.5 in the 1/4mile
This is the T-Get works this car is also 500ps ran a 10.6 in the 1/4
GT3040
I am going home so I will finish at home
Old Mar 1, 2006 | 04:29 PM
BigVinnie's Avatar
I'm amazed most enthusiasts thought the little 1.8 litre couldn't achieve past 450HP, without blowing the valve train.
It's the little choo choo train that could....LOL I mean engine
Old Mar 1, 2006 | 05:09 PM
Love the CA18, if I wasn't gonna keep the KA or if I ever blow it I think thats the route I would go
Old Mar 1, 2006 | 05:11 PM
I am still not convinced that these cars lasted very long, I had a 490whp CA and it was well built block was perfect, the head was perfect, I had everything ported polished, the block decked cleaned, oile pump was rounded out, ported a little and polished, new bearings, full Tomei head, cams,Cam gears, the works I spent alot of money on it
After it was broken in I coule boost the TO4R to 1.6 and I was off hit up two drag events and the thing started overheating and could never find the cause
New Big *** radiator, New 63deg thermostat, New twin FAL fans, water jackets were cleaned and blown out. The whole cooling system was new and or made better.
Old Mar 1, 2006 | 06:40 PM
broke_s13's Avatar
i had 3 ca's in one car i wish mine could have held up...haha
Old Mar 1, 2006 | 06:58 PM
Yeah they are not very reliable when it comes down to it, I think the whole aluminum/Iron thing is just a waste despite a good metal headgasket
Old Mar 1, 2006 | 07:33 PM
broke_s13's Avatar
well when you drift and just redline the crap out of it it doesnt hold up long but at like 250 to 350 a pop from a junkyard i didnt complain
Old Mar 1, 2006 | 07:46 PM
yeah true
Old Mar 2, 2006 | 01:44 PM
broke_s13's Avatar
your heating problem...all ca's must have that mine always over heated...always blew the water line behind the engine...
Old Mar 2, 2006 | 04:03 PM
Yeah the enigne that I fully built was taken real good care of. We ran a micro-rotary tool through all the water channels opened them up a little and polished them It is hard to explain I was drag racing the car and it still overheated. Oh well the are out of date good for their time but out of date.
Old Mar 2, 2006 | 04:23 PM
BigVinnie's Avatar
There are ways that could of cooled the engine from over heating, such as windage trays and scrapers to cool oil fast, and even using a dry sump system.
The problem wasn't the coolant system.
Old Mar 2, 2006 | 04:47 PM
broke_s13's Avatar
haha your right...it wasnt a the coolant system is just the CA...haha...but yeah my CA alwas always boosted at 1.5 quick for the little thing
Old Mar 2, 2006 | 05:01 PM
I had Setrab Oil cooler with cooling fans, 3 core Copper radiator, vented hood which was damaged during the swap, There is nothing much different then the way I have my SR set up now the CA is just an Overheat monster. There is nothing I did think of when it cam to cooling that engine. Too much power on a fully built engine, just took it's toll the car was flowing air Right then I just ripped the CA out and dropped in the SR never had that problem again.
This was the day after I dropped the engine in . I just got the car back from the paint shop. This is an 1988 S13 that previously had TO4R fully built CA.
Old Mar 2, 2006 | 07:05 PM
BigVinnie's Avatar
What was the CR on the CA?
Old Mar 2, 2006 | 07:51 PM
Don't remember it was like 8 years ago but it was freshly built Tomei pistons, rods, Crank, Fully built head. I am am thinking it was 150 all the way across (1.2mm headgasket)
2jz240sx
Feb 20, 2007 06:55 PM
spitz7985
Jan 10, 2006 05:21 PM
japporeyser
Jun 13, 2005 09:09 PM
unreal89
Apr 10, 2003 06:53 PM
Super Dude
Feb 1, 2003 07:24 PM
