Can anybody explain why striaght pipe will lose low end torque?
Old May 27, 2005 | 04:43 PM
jackyliem's Avatar
yea. I am wondering why that happen? I was think about that if the exhaust pressure is low it wound take more force to compress the exhaust valve spring, therefore the drive train will lose some of the torque. But my friend said that the for the to compress exhaust valve spring shouldn't matter that much.
Old May 28, 2005 | 11:14 AM
lrb_2000's Avatar
do you mean replacing the catalytic converter with a striaght piece, or the whole exhaust?
Old May 28, 2005 | 12:15 PM
jackyliem's Avatar
well I know both way should lose low rpm torque, of course the whole exhaust should be more significant. it would be good if someone explain both. thx
Old May 28, 2005 | 12:17 PM
M374llic4's Avatar
you lose back pressure when its a straight pipe, so it flows alot better at the high rpms, but you lose the pressure at the low, so you lose some power.
Old May 28, 2005 | 02:58 PM
lrb_2000's Avatar
that depends on the size of the piping... and whether it's turbo, or n/a...
Old May 29, 2005 | 12:29 AM
jackyliem's Avatar
well. lose what kind of pressure at the low? like the pressure in the combusting cyclinder? or the exhaust header?
Old May 30, 2005 | 07:19 AM
Texas240's Avatar
backpressure is for carbe'd cars, not ours.
you'd run outtal torque b/c there would be too much air. essentially you'd be leaning out the engine.
If you advanced your timing and increased fuel, you could compensate to a point.
Old May 30, 2005 | 06:44 PM
jackyliem's Avatar
oh I thought the MAF will take care of the fuel mixture problem. anyway thanks for the input
Old May 31, 2005 | 12:15 PM
ArticDragon's Avatar
Backpressure is to help in evacuating the cyclinder of exhaust gases IIRC.
driftfreek
Oct 9, 2006 06:09 PM
cgnismo240
Apr 1, 2004 06:52 PM
meangreen240
Mar 11, 2004 07:46 PM
leiferik1
Nov 15, 2002 09:54 PM
