can someone explain...
Old Apr 1, 2004 | 12:30 PM
cgnismo240's Avatar
I'm really confused about offsets and stuff, would someone mined explaining them to me. I'm lookin at rims and I want make sure that they will fit well.
Here are the rims: http://www.carxpressions.com/wheels/falken.htm
The torque 5's in gunmetal, I think I may go with the 17's, any help is appreciated.
Old Apr 1, 2004 | 01:07 PM
smokie700's Avatar
offset is the relation of where you bolt to the hub from the rim.
A center offset is the middle of the rim is in the center of the overall rim width.
So a rim that is 10 inched wide will have a center offset 5 inches from the edge of the rim.
If the it has a negative offset it will be 4 or less from the edge closet to the engine
A positive is anything from 6 or more from the edge.
I may have the negative and postitive but im sure someone will correct me.
Old Apr 1, 2004 | 05:34 PM
cgnismo240's Avatar
thanks man, I appreciate it. Would you happen to know what the stock offsets are for a 96' 240 with the alloy wheels?
Old Apr 1, 2004 | 06:52 PM
Catharsis's Avatar
they are +40 but i wouldnt get anyting around that offset for stock, go with more of a +25
jackyliem
May 31, 2005 12:15 PM
leiferik1
Mar 30, 2003 10:15 AM
leiferik1
Nov 15, 2002 09:54 PM
GTspecR
Mid Atlantic
Jun 25, 2002 05:59 PM
