Cant get my dash off!!
Old Sep 11, 2005 | 04:20 PM
Atown 240's Avatar
Angry Cant get my dash off!!
I'm trying to install my glow gauges but i cant get my dash off. It wont go around the lever for making the steering wheel go up. How do i get it off!!!!!!!! I'm trying everyway to get it around it but i cant.
-joe
Old Sep 11, 2005 | 07:25 PM
h22lude's Avatar
By dash I hope you mean the piece that goes around the instrument panel. There is no need to take your whole dash out.
If you are taking about that black piece around the cluster, you just need to work at it and move it around. It is a pain in the *** to do but it comes. I forced the plastic piece on the bottom left side over the steering steering column.
Old Sep 11, 2005 | 08:45 PM
KerosineK's Avatar
Re: Cant get my dash off!!
-joe
Try unscrewing it, just a guess...
Old Sep 11, 2005 | 08:58 PM
Atown 240's Avatar
i got it, came out nice but now my rpm gauge doesn't work
Old Sep 12, 2005 | 11:01 AM
ghostman's Avatar
oh man you didnt remove the needles and the reinstall them did you? thats a big no no. anyways if you installed them the right way, most likely the needle is just getting stuck because the gauge is not fully pressed down (commom problem with glow gauges). try using some double sided tape....that should hold it down good enough for the needle to move freely. although there are some instances where the gauge is just too thick and wont work period.
Old Sep 12, 2005 | 11:14 AM
2fast4y0u's Avatar
if you did remove the needle. you have to wind it back up. they probably didnt tell you to remove the little pin that the needle sits on and mark were the needle falls to... well, take out the pin wind your needle counter clock wise a little bit, go out and drive your car and see were its at. you ave to adjust it that way or your screwed. it probably wont ever be perfectly correct again.
Old Sep 12, 2005 | 04:05 PM
Atown 240's Avatar
It onyl works around 5-6k rpm. it'll move up to like 2 butthats it. It's ok i dont need it. i got a auto
nismoman
Mar 14, 2007 08:03 PM
soon2boost
Mar 13, 2007 02:15 PM
santana
Apr 30, 2005 11:11 AM
chriskelchner
Jul 15, 2004 06:54 PM
DrftDmn
Jun 7, 2003 11:40 PM
