oil level light is on and off in the dash!!
Old Mar 13, 2007 | 10:56 PM
nismoman's Avatar
I checked my oil level and it is at high so the light should not be on. When engine is just started, the light is not on however, when I drive it around, the light will come on and might go out sometimes when I hit bumps but comes back again. I checked the oil pan and it is straight and no dents.
Couple of things that I can think of are: Bad oil pressure pump, bad oil pressure sensor next to oil filter.
What do you guys all think??
Old Mar 14, 2007 | 05:56 AM
e brake bro. that lil sensor on there gets loose over time. ill take a picture for you and post it. you just have to bend it back.
ill put it up after i get home from work.
Old Mar 14, 2007 | 06:03 AM
I have the same prob on my daily driver. The oil light flickers on and off, esp if I am going down hill & Brake. It prob needs a change and top off, since i havent done that in a while. Then again i dont give a F about my Daily beater lawlz
Old Mar 14, 2007 | 07:42 AM
nismoman's Avatar
e brake??
I am confused, I dont know how e brake got to do with this?? Let me know, thanks
Old Mar 14, 2007 | 10:19 AM
I believe he thought you were talking about the brake light in your dash. I would check the sensor and wiring since it seems to happen when something jars the car.
Old Mar 14, 2007 | 01:14 PM
heres your picture
what happens is the plunger gets loose over the years and it hits the other contact point. you just have to bend it back a bit.
also check you brake fluid level just to be careful.
but im sure it is the e brake sensor
Old Mar 14, 2007 | 03:31 PM
re037's Avatar
prob your oil pressure switch, its by the oil filter
Old Mar 14, 2007 | 03:38 PM
that would just fail all together.
its the switch that i showed the picture for. i was checking all that jazz and when i check that switch, that was the problem.
Old Mar 14, 2007 | 04:05 PM
re037's Avatar
i think hes talking about the *oil* light like bryan said =)
Old Mar 14, 2007 | 04:07 PM
ohhh **** bro....... i must be drunk...
good info just wrong issue. lol
Old Mar 14, 2007 | 05:06 PM
oh **** dont worry biggamehit, that was all good info you were giving. You get an A for effort. Lawlz but yeah lay off the brewskis hahaha & get the R32 already.
Old Mar 14, 2007 | 05:42 PM
DUDE speaking of that, just found out It may be a chance that i can get out of here before i got to Iraq...... hmmmmmmm
Old Mar 14, 2007 | 07:09 PM
get out of the Air Force? or get the R32? We are hanging out when you get it right brah?? *wink*wink*
Old Mar 14, 2007 | 07:26 PM
hell no lol go to japan
im staying in the Air force for the next 19 years lol
Old Mar 14, 2007 | 08:03 PM
hell yeah man Air Force for life. But u still are getting the R32 rite?
AxisKill
Oct 23, 2005 11:18 AM
sirenx
Sep 1, 2005 04:29 PM
supersteven
Jul 23, 2005 09:38 AM
michael
Dec 15, 2004 07:24 PM
craigkiel
Mar 6, 2004 09:43 PM
