chain
Old Jul 28, 2004 | 01:06 PM
ignigknot's Avatar
chain
My 240 has been idling irregular for the past couple days. I took out the aiv like recommended by some. It didnt fix the problem. I opened the hood this morning and i hood a small sscrapping like sound coming from the engine. I recently fixed nd put in new parts for the bottom timing chain so it cant be that. But when i put it back together the top chain was a lil loose but i left it because when i cranked the engine it would tighten by oil pressure. JW if it is the top timing chain that could be causing my problem.
Old Jul 28, 2004 | 04:36 PM
Its the top tensioner. You fixed the wrong one lol
Old Jul 28, 2004 | 07:45 PM
ignigknot's Avatar
no i didnt fix the wrong one cuz the bottom one had no guide and the tensioner was completly jammed.
ignigknot's Avatar
and i cleaned out the top tensioner also when i put it back together so i thought it would be ok
Old Jul 28, 2004 | 08:04 PM
bullheadd1nismo's Avatar
yea hyjynx said it right you fixed the wrong one. check again
Old Jul 28, 2004 | 08:26 PM
ignigknot's Avatar
did u not just read what i wrot at all lol i did have to fix the bottom it had no guide it was in pieces in the oil tank and the tensioner for that was shot had to buy a new one. The top was fine at the time but a lil loose at a certain spot when u cranked the engine i thought it was ok because it would tighten right after because of the pressure. Is that normal for the top thats all i wanna know?!?!?!
Old Jul 28, 2004 | 11:44 PM
...once again its your top tensioner.
240's have a problem with the top tensioner getting loose,a nd after awhile just not working well, thus leading to bigger problems.
Imungree
May 15, 2004 04:16 PM
TexRauder
Mar 23, 2003 06:21 PM
spitz7985
Dec 23, 2002 05:32 AM
SKWERLZ 240
Dec 6, 2002 12:06 AM
spitz7985
Oct 8, 2002 03:34 PM
