damn shift knob
Old Dec 28, 2003 | 09:50 PM
too forty's Avatar
damn shift ****
this is a very noob question, but ive searched for the answer..couldnt really find it. i was going to install a short shift kit, and i know the first step was getting off the **** so i was trying to see how easy that was. all the threads say...just twist it off, but when i tried to twist, it would bend but not untwist. i know i was turning the right way, any reason for it to not wanna come off?
Old Dec 28, 2003 | 10:11 PM
Its just on...REALLY tight. Sometimes I just give up....pour a bucket of WD 40 on it, let it sit then go at it haha. Well I ahvent done that...but wd40 MIGHT work?
Old Dec 29, 2003 | 01:20 AM
It is really really hard to get off and I think I broke my wrist in the process, but the way I did it was...(I hope I explain this good enough) I took a towel and layed it over top of the ****. Then I took the dangling part of the towel and twisted it together. I took plyers and grabbed the twisted knotted part of the towel and twisted with that. It took a little bit of muscle but I got that sum***** off
Old Dec 29, 2003 | 03:39 AM
ixcocoyxi's Avatar
easy>> wrap a towel around the ****.. get a VICEGRIP!! counter-clockwise.. BAM! removed
Old Dec 29, 2003 | 10:48 AM
cocoys might be the easiest
Old Dec 29, 2003 | 05:14 PM
WilloW's Avatar
I think they put some kind of glue or loctite on that lil **** from Nissan. I went at it with a vice grip on my s14.
Old Dec 29, 2003 | 11:26 PM
Ronin|One's Avatar
Re: damn shift ****
you turned it the right way? your suppose to turn it left, counter clockwise... try that and get back to me when you got it off!
Old Dec 30, 2003 | 04:32 AM
Re: Re: damn shift ****
I think when he said he turned the right way he meant that he was turning it the proper way (which is left/counter clockwise), not that he was twisting it to the right
Old Dec 30, 2003 | 07:11 AM
Jeffro's Avatar
Sears has this "strap wrech"....might be worth shot if nothing else works.
good luck
Old Dec 30, 2003 | 08:27 AM
NcTwOfOuRtY's Avatar
or another idea is this pb buster you can get at your local hardware store its also known as nut buster thats what always usually helps me free up anything im having problems loosening, its kinda like wd40 i guess but they say its better for that sort of thing, or since your gettin a short shifter put in just pull down the shift boot and take a cut off wheel to the shifter and saw it off! only as a last resort though unless you dont have patience like me
hkspeed
Oct 1, 2005 05:34 AM
Bryan
Aug 24, 2003 03:40 PM
leiferik1
May 30, 2003 02:48 PM
89240sxmup
Nov 17, 2002 03:23 PM
Jonas
Oct 6, 2002 01:20 PM
