electric fan advise
Old Mar 27, 2008 | 12:01 AM
Darkvillin's Avatar
electric fan advise
Im just curious as to which model year altima to take the electric fans from. I have my motor n engine bay torn apart anyway, so id like to put in these fans n just have them come on when I turn the key. I've seen a few write ups but nothing is mentioned. Any advise is appreciated. Thanks guys.
Old Mar 29, 2008 | 02:09 PM
i don't hava definite answer because there really isn't one. altima fans are a popular choice because they fit right on the 240 radiator core, are fairly cheap, slim and so forth. ford torus and pontiac fiero fans are two other fans that are popular for some of the same reasons. i welded two ac condenser fans together and used that.
just get a fan that is slim enough to fit and big enough to push or pull a sufficient amount of cfm. also it would be in your best interest if you used a temp switch to control the fans instead of having them on all the time. if you haven't seen this already you should read it.
https://www.s-chassis.com/forums/how-tos-installations-48/electric-fan-install-41909/
Old Mar 29, 2008 | 03:45 PM
Darkvillin's Avatar
thanks for the advice brother. much appreciated. i gotta do something to keep my car cool because it runs like a bogged down p.o.s when it gets hot. my temp guage just flapps all over the place too. i gotta figure that one out still. lol. again, thank you.
Old Mar 29, 2008 | 04:06 PM
the temp gauge is most likley either air in the coolant system, bad stat or a faultily temp sending unit.
ignigknot
Jul 13, 2004 01:48 PM
BMadd
Mar 4, 2004 07:43 AM
4984 5fsdskfvjdsntr4
Oct 23, 2003 04:10 PM
Doba's240
Oct 20, 2003 09:22 PM
Driftin180SX
Feb 25, 2003 01:51 PM
