Engine Problems
Engine Problems
Alright, here is what is going on...
My engine will only start with a jump from another car/charging it. I just put in a new battery because of this problem yesterday. It clicks when you turn the key, you know like 'click click click click'. I don't think it is the starter at all. I think it is the alternator. Anyone have any ideas? I'm lost
EDIT: Also, I put a bit too much engine oil in it...could that be it?
Lucas
.EDIT: Also, I put a bit too much engine oil in it...could that be it?
Lucas
You cab check your alternator and starter at kregan auto parts. Just take ur car there and say u want an alternator/starter test, its free. and drain out ur extra oil until it is at the right level.
Originally posted by -HyJynX- when u changed the battery did it start up perfectly? Or start at all? Gatta be either the starter or alter.
I might just break down and get it checked out by a real mechanic.
Originally posted by Romeyo07
sounds to me like a bad alternator. it's not charging your batter while it's on, hence it running out of juice and not starting up when you try it again.
bro, sounds like ur alternator is bad, ive heard u can take it to a shop and then will fix it up for u, or u can buy a new one. Pretty sure its the alternator though
Originally posted by 240 Freak
Well, luckily I called up a friend, and fellow 240sx owner, and he recently purchased a wrecked '90 coupe. I'm getting the starter and alt. for $100.
Thanks guys
Thanks guys
It could possibly be more than that
Check the battery with a voltmeter and it should read ~12.6, anything less and your battery isn't good. Then check the ground wire, because if it's not grounding correctly thats your problem right there. When your car is jump started, check the battery again, it should read ~13.6 or so, because the alternator should be juicing the car.
Thats the best place to start.
Dr.
Dr.
Re: Engine Problems
... It clicks when you turn the key, you know like 'click click click click'.
Stupid Hondas.
I was told the exact opposite, and had the exact opposite happen to me. Intermittently my s13 wouldn't start, you'd turn the key over, it would click once and nothing would happen. So I would get out and smack the **** out of the starter, err, caress it, and it would start. Finally it got to the point when it took 2 hours of coaxing for the starter to work, so I replaced it.
I would only click once and nothing would happen.
Dr.
Dr.
Dr is right, if it goes click click click click thats the starter trying to start but doesnt have the juice for it or theres another problem. If there is only a click or 2 and stops then the starter is starting to go bad. Just my $.02
