Fans
Fans
Newbee ? I have a 91 240sx with 2 fans believe 1 electric conected to the radiator and 1 connected to the front of the motor. My ? is do I need the belt driven fan or can it be removed. I just finished replacing my front seal and relized the belt was so loose the fan wasnt spinning anyway.
thx
thx
Well thx for the obvious but I know how to fix the fan! ? is I removed the A/C unit looking to clean up the engine bay so is 2 fans needed if im not running A/C or will the factory electric fan be enough?
Take the electric fan and wire it to a switch or an actual thermostat. In normal conditions (no boost) that fan is enough to keep the motor cool at idle. It is the condenser fan (for the A/C) but I always just rewire it to use it and get rid of the clutch fan.
