flushing coolant
Old Nov 26, 2002 | 09:15 AM
rbboyl's Avatar
Regulate
flushing coolant
How often should you flush your coolant?
I bought my car at 86k, and I don't know if the previous owners ever did it.
Old Nov 26, 2002 | 11:16 AM
rash's Avatar
Cool (¯`•—»rash«—•´¯) ³
I change a flushing coolant 7 months ago.
But in my opinion maybe i need to do the change each 5 moths..
Old Nov 26, 2002 | 12:38 PM
Rockstar240's Avatar
I change my coolant about twice a year in the spring before it gets hot and in the fall before it gets cold.
Old Nov 26, 2002 | 01:39 PM
spitz7985's Avatar
Old Nov 27, 2002 | 09:01 AM
rbboyl's Avatar
Regulate
Hmm, ok. Do you guys do this yourself?
Old Nov 27, 2002 | 09:48 AM
it's not hard. It's easier than an oil change. Actually, it's like changing your oil without changing the filter, except filling it up is different. And there's a ratio of water to coolant that people tend to choose. Sometimes 50/50, 60/40......and so on. Oh Yeah....to answer your question......yeah I change it myself.
My friend bought his RX-7 and the person who had it before never changed his coolant. So, we decided to change it. When we drained it, the coolant was brown with dead insects in it. I found that odd, but changing your coolant is a must.
Old Nov 27, 2002 | 09:58 AM
spitz7985's Avatar
they sell coolant flushing kits at hardware stores for like 5$
Old Nov 30, 2002 | 11:45 AM
rbboyl's Avatar
Regulate
Ok, I think its time to change my coolant. It's starting to take on a dark green color. Thanks guys.
So all I need would be a coolant flushing kit?
I should get a manual.
Old Nov 30, 2002 | 11:57 AM
Import Fanatix's Avatar
Very good move!! It tells you how to do it which is easy and plus it tells you how to purge the air from the system, which tends to overheat if it has air in it.
Old Dec 1, 2002 | 07:34 PM
ºMidnightºMixº's Avatar
antifreeze every 3years green coolant
5years for orange coolant most newer cars vw,lex etc.
Basically drain fill with water or flushing coolant. refill water, drain then add mix 50/50. Be sure to account for antifreeze in the block try and locate the drain plug located somewhere on the block. if not just do a heavier mix of antifreeze as water is in the block already.. 60/40 watermix
Old Dec 2, 2002 | 03:13 AM
NightSlide Josh's Avatar
actually..
this is what my book tells me to do..
flush and remove all coolant..
now plug it up then fill it up with water..
run the engine till warm
or when thermostat opens
then kill engine drain water
repeat until the drained crap no longer looks **** green
then fill with a 60/40 mix
60 % coolant and 40% water
it gives the best of both worlds..
50 / 50 mix sacrafices a couple of degrees of boiling temp
JDMxDrift
Jun 19, 2005 10:10 PM
drifterswanted
Dec 10, 2003 06:48 PM
Jonas
Aug 3, 2003 10:19 PM
cjm93240sx
May 19, 2003 08:29 PM
flarearrow
Northeast
16
Apr 7, 2002 08:22 PM
