grinding suspension (pics)
Old May 1, 2005 | 04:58 PM
Mika's Avatar
sooo i get this really loud *** grind in my suspension when i make a fairly sharp left turn and today my dad and i jacked up the car and took a look, now neither one of us is an expert car mechanic but we think we found the problem, he also said looks like we could replace it fairly easily but we need some booklet (sorry the name has slipped my mind)
wat do u guys think?
Old May 1, 2005 | 05:03 PM
tenzenk's Avatar
what's the problem? what needs to be replaced? I dont think that caliper bolt is rubbing anything.
Old May 1, 2005 | 05:39 PM
Mika's Avatar
dad says he thinks that that's a bearing thats broken and it should be straightly aligned...but as i said were no experts, so i came here
Old May 1, 2005 | 06:22 PM
wikd240's Avatar
here is a link for the fsm or the booklet thing you were talking about... it is a little way down under s14
http://www.zeroyon.com/index/content/view/24/47/
Old May 2, 2005 | 03:22 PM
AAV240sx's Avatar
Looks like a oozing oem TC rod bushing needs to be replaced. I replaced mine a while ago. It's really easy to replace if you got a press.
Old May 2, 2005 | 05:36 PM
CowboyTurbo's Avatar
yeh ur going to need mechanic tools to get that out or else it's going to suck
Old May 2, 2005 | 06:49 PM
Mika's Avatar
well i had it towed to my moms mechanic friend, hopefully its not gonna cost too much and i hope i can get myc ar back soon
Old May 2, 2005 | 07:12 PM
needa240's Avatar
shouldn't be over 100 bucks. That is easy to replace with the right tools.
no more than 1 hour.
Old May 2, 2005 | 10:25 PM
naptime's Avatar
Tc rods. It is a 10yr old car. let us know how easy the fix was
Old May 4, 2005 | 12:28 PM
Mika's Avatar
guy said it was the wheel bearing, cost me 150, im waiting to go pick upt he car soon and we'll see how it goes from there
Old May 4, 2005 | 05:31 PM
Mika's Avatar
NO MORE GRINDING !
Old May 4, 2005 | 08:17 PM
aay's Avatar
aay
You might still want to get the TC rod/bushing changed even if the grinding noises are gone. A worn bushing like that leads to knocks when turning at full lock and makes for weird feeling steering at highway speeds.
Unfortunately, Nissan does not sell bushings seperately, but the entire tension rod is available from them. I paid $55 for mine. If you have access to a press, you can buy a set of replacement bushings for the cost of one new tension rod...
The rod itself is pretty easy to remove - it's held in place by three bolts.
Old May 5, 2005 | 09:58 AM
2forties's Avatar
Banned
Does the energy suspension contain replacment tension rod bushings in there kit?
Old May 16, 2005 | 09:31 PM
kang128's Avatar
yes it does
studly698
Nov 19, 2012 11:08 PM
fast240
May 7, 2004 08:50 PM
epoxy
Jan 30, 2004 12:12 AM
ryan15
Jan 28, 2004 10:59 AM
Tex
Dec 13, 2003 09:55 AM
